Kast Weld 111 source?
发表于 2021-8-31 23:51:26 | 显示全部楼层 |阅读模式
It's time for me to try some O/A cast welding.Where do you boys buy your kast weld 111 or equivalent rod?My local sources are clueless. On line search has not been fruitful so far. ThanksDaveDave Koehler   http://www.koehlerinjection.comLincoln square wave 300 tigO/A
Reply:Dave, Last I checked with Harris, they had lost their supplier for the 111 and were getting another supplier on-line. Aufhauser has the same alloy material in stock and the local welding shop should be able to get it for you. Pick up the flux from them as well if you dont have any. As far as the local welding shop being clueless, they are no different then the majority of the welding community, the knowledge has been lost to the sea of 110v mig welders and OCC wannabe tig weldors. The materials and processes are still being used daily by professional shops, but these unfortunately are not the people who do TV shows or internet forums. Good Luck! I think you will like the process and the results!-Aaron
Reply:Can you elaborate? At my expense of sounding ignorant?
Reply:Originally Posted by pistolnoonCan you elaborate? At my expense of sounding ignorant?
GMT+8, 2025-12-24 20:02 , Processed in 0.164635 second(s), 18 queries .
