Hobart 140 or Lincoln 3200HD
发表于 2021-8-31 23:51:26 | 显示全部楼层 |阅读模式
Going to be one or the other, which would you recommend? Thank you guys.Daniel 5:23
Reply:Lincoln 3200HDThe Welder Shop has great deals and reviews on Hobart, Miller and Lincoln Welders.
Reply:The Hobart. That version of the Lincoln is the cheap home improvement store version. run a search on here, you'll see some issues. If you do decide on the Lincoln, get the sp135 version.John -  fabricator extraordinaire, car nut!-  bleeding Miller blue! http://www.weldfabzone.com
Reply:The Lincoln 3200HD was MFG'd just for Home Depot  (HD), I believe it only carries a 1 year warranty. The HH140 will carry the standard 3 year warranty. You won't see the 3200HD at any industrial welding supply store.
Reply:That settles it. Thanks.Daniel 5:23
Reply:Originally Posted by KSellonThe Lincoln 3200HD was MFG'd just for Home Depot  (HD), I believe it only carries a 1 year warranty. The HH140 will carry the standard 3 year warranty. You won't see the 3200HD at any industrial welding supply store.
GMT+8, 2025-12-24 16:53 , Processed in 0.074763 second(s), 18 queries .
