Question on aluminum
发表于 2021-8-31 23:51:22 | 显示全部楼层 |阅读模式
I've got a Millermatic XP130 wire welder. I have only used flux cored wire in the welder, I do not have gas for it. If I were to buy a roll of aluminum welding wire, can I weld aluminum or will it have to require a gas with it to do that ?
Reply:need argonMiller Xmt 350Lincoln Ln-25Ahp 200xSmith Gas Mixer AR/HTig is my Kung FuThrowing down dimes and weaving aboutInstagram http://instagram.com/[email protected]
Reply:I kinda figured.... Ok, well thanks a lot !!!! Rick
Reply:Also w/out a spool gun you w likely throw things.HammerFile Big Hammer------------------------------Here, let me Google that for you...
Reply:Originally Posted by lamenameAlso w/out a spool gun you w likely throw things.
GMT+8, 2025-12-24 18:38 , Processed in 0.090449 second(s), 18 queries .
