Which Everlast welder should I buy?
发表于 2021-8-31 16:58:51 | 显示全部楼层 |阅读模式
I currently have an AHP AlphaTig 200x TIG welder that has served me well for 5 years, but it's been having issuesI figure I'd get a new Everlast welder. I have 220v access and I mainly TIG weld steel, but sometimes do stick 6011 or 7018. I'd like the ability to TIG aluminum and I mostly have max amps set at around 130. I'm thinking the 210 EXT?Do these welders come with evrything, torch, pedal, etc? Do they have the superflex cable?
Reply:If Aluminum is in your future, I'd consider paying the difference for a 250A machine (or you're going to limit yourself to 1/8 or maybe 3/16). Alum just sucks-up those Amps As far as I know, their machines come with those accessories but they have their own line of "SuperFlex" like torches and that's probably not going to be what's in the box...
Reply:Yes, if you buy direct from us, you get two torches, a pedal, regulator, work clamp, stick torch and small consumable starter kit.  As well as a 240 to 120V adapter.  You can upgrade to a better package, and we can custom assemble you a package if you call in direct.  If you'd like to get one, let me know.  877 755 9353 ext 204.I'd look at either the 210EXT or the 255EXT (for more power, additional wave form, spot timer function, better stick welding capability).Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Originally Posted by PcmakerI currently have an AHP AlphaTig 200x TIG welder that has served me well for 5 years, but it's been having issuesI figure I'd get a new Everlast welder. I have 220v access and I mainly TIG weld steel, but sometimes do stick 6011 or 7018. I'd like the ability to TIG aluminum and I mostly have max amps set at around 130. I'm thinking the 210 EXT?Do these welders come with evrything, torch, pedal, etc? Do they have the superflex cable?
Reply:I bought a new mill so the welder has to wait awhile
Reply:Originally Posted by PcmakerI bought a new mill so the welder has to wait awhile
Reply:Learn to use the Advanced AC pulse It'll soar over 1/2".Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Learn to use the Advanced AC pulse It'll soar over 1/2"...Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:I have to say,,, when my old PP256 crapped-out and was replaced by a 255EXT, that Advanced Square Wave really did make a noticeable difference in thicker aluminum.
GMT+8, 2025-12-19 00:35 , Processed in 0.163689 second(s), 18 queries .
