查看: 13|回复: 0
man, monkies, some marsupials, and some ho's have these.
发表于 2021-8-31 23:51:16 | 显示全部楼层 |阅读模式
Track hoe's that is.One of this weeks projects.A (non hydraulic) thumb for a Cat 110 (25,000 lb) track hoe.I used 3/4" x 7" hot rolled flat bar, 3" x 3" x 1/4" wall tube, 1-1/2" sch 80 pipe, and 1-1/2" hot rolled solid round bar for the pins.It's 4'-0" long, 11-1/2" wide (outside to outside) and weighs about a metric s**t load.I was supposed to go put it on today, but I took too long to finish it up, so it gets installed tomorrow am.I don't see the resemblance.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:awesome work. its always good when you get to do big heavy work with no regard to lightweight dainty concerns. nice looking peice.
Reply:The scale had me confused for a bit.  At first I thought those were tig welds.   Then I read the post....City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:Got -r-done.One job down, 6 more to go. 7 counting the little job the dirt contractor sent me home withUgh, it's hot.Had to keep moving the hoe into the shade.I forgot to take close ups of a beadUsed a Ranger 2-fiddy at 160-ish amps with 5/32 7018, and 135-ish amps with 1/8 7018.I went over each joint 100% 3 times. (Is that 300%?)Gotta love that "Chopper Technology", lays a real sweet bead.Brian LeonardAppalachian Ironworks L.L.C.434 Long Branch Rd, Marshall, NC 28753828 649 9966828 702 [email protected]
Reply:Definatly an odd looking thumb. I'm sure theres a reason for the pin at the tooth end, but I can't imagine it right now..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2025-12-24 20:02 , Processed in 0.099137 second(s), 18 queries .
