Parweld or sureweld ?
发表于 2021-8-31 23:51:09 | 显示全部楼层 |阅读模式
Help.... I've been welding for years but had the fortune of using mostly miller so have no expierience with eith sureweld or parweld and now need to buy a tig machine. looking at the 180's The only obvious difference is the sureweld body looks more solid but the parweld is duel voltage which could be handy. any help much apprieciated.Sam
Reply:sureweld parweld never herd of either must be spending to much time on ebay the way times are now i would not buy a welder or plasma cutterfrom china a lot of import companys are going to go bankrup then you are going to be stuck with what you bought in the first place junk junk junk
GMT+8, 2025-12-24 17:02 , Processed in 0.097068 second(s), 18 queries .
