Lincoln 300/300
发表于 2021-8-31 23:51:08 | 显示全部楼层 |阅读模式
Any ideas on what to look for in repairing an old Lincoln welder which just lost the high frequency start?  I can still Tig weld with it, if I drag the electrode on the metal and it welds good.   I checked the spark gap in the cover in the front.  any other ideas?  Do you think this would be expensive to fix?THanksMark
Reply:Check for any grounding of HF components, more than likely it will be the HF capacitorCheers
Reply:I completely took out the contact points of the spark gap and scrapped and lightly sanded the surface. I put it together and set the gap. I did a quick test and looks like it works.  I just need to do some more welding and see if is fixed for sure.  Thanks.
GMT+8, 2025-12-24 17:02 , Processed in 0.105303 second(s), 18 queries .
