6013 question
发表于 2021-8-31 23:51:08 | 显示全部楼层 |阅读模式
a 6013 rod on dc positive is a medium to low petration rod correct i just askin me and a friend are in argument a 6010 is a deeper penetrating rod
Reply:6010 is deeper yesonly thing worse than an ugly woman is an ugly weld
Reply:6013 is a low penetration rod excellent for part build up and repair of non critical cast steel. ...6010 digs about as deep as you can get.  A 6011 is a deep  penetrating rod as well.  7014 is a low but slightly more penetration than a 6013..Who won?Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:6013 is a medium penetation all position, general purpose rod.That information is right out of my pocket welding book by Hobart company.6010 is a deep penetration rod with very little build up. It is often used for a root pass on pipe.6011 is also a lot like 6010 and is often used on galvinized pipe like chainlink fences.they both have a nitro cellulose base.AWS certified welding inspectorAWS certified welder
Reply:yea thanks i just made me fifty bucks i thought thats how it was and my friend had diffrent thoughts but thanks everyone
Reply:Originally Posted by lugweld6013 is a low penetration rod excellent for part build up and repair of non critical cast steel. ...6010 digs about as deep as you can get.  A 6011 is a deep  penetrating rod as well.  7014 is a low but slightly more penetration than a 6013..Who won?
Reply:Farmersam,  you talkin about cast STEEL or cast IRON.David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David RFarmersam,  you talkin about cast STEEL or cast IRON.David
Reply:7018 for cast steel, never tired 6013.   7018 takes on some of the properties of the parent metal.  I don't know about 6013.  Its truly a sheet metal rod.Real world weldin.  When I grow up I want to be a tig weldor.
Reply:Originally Posted by David R7018 for cast steel, never tired 6013.   7018 takes on some of the properties of the parent metal.  I don't know about 6013.  Its truly a sheet metal rod.
GMT+8, 2025-12-24 16:54 , Processed in 0.065375 second(s), 18 queries .
