Cheap welder using auto alternator
发表于 2021-8-31 23:51:06 | 显示全部楼层 |阅读模式
I thought this was an interesting way to make a cheap DC welder. I have a 6 HP Yanmar diesel engine in the barn that I don't use and thought this would be a use for it.http://www.motherearthnews.com/Do-It...rc-Welder.aspx
Reply:thanks for the post taz!I've been looking into making an onboard welder for my explorer. Here is the link to what i was looking at. the thing i like about it is the fact that you can run power tools off it as well. This would be great for side jobs!http://www.pirate4x4.com/tech/on-boardwelder/
Reply:BTW, I'm sure you could set cruise control instead of the adjustable throttle to save some cash
Reply:uh, it would be kinda hard to weld while running along side the truck at 30mph.Tim Beeker.
Reply:taz, here's another one i read a while back. 1/2" plate tig, and the guy says its the best stick/tig unit hes ever used lolhttp://www.hotrodders.com/forum/my-d...der-77730.htmlhe uses a bike gear shifter for throttle control
Reply:Originally Posted by tnjinduh, it would be kinda hard to weld while running along side the truck at 30mph.
GMT+8, 2025-12-24 16:53 , Processed in 0.088264 second(s), 18 queries .
