looking to buy some square hot rolled tubing for a table. Someone piped in and told me that onlinemetals.com was kind of a rip...so what should I be paying for something like2x2 1/8 thick2x2 3/18 thickI called my local metal place and they only carry stainless, so Im going to have to find another place. Im just trying not to get ripped off.ThanksLast edited by BlauSchuh; 07-08-2010 at 05:47 PM.Reason: hit post prematurelyESAB Heliarc 252
Reply:I recently purchased a couple of sticks (24' lengths) of 2x2x11 gauge for $36.72 per stick. This is $.50 per pound.I wouldn't purchase metal online unless it was my only option. Local pick up should be a billion times cheaper (well maybe not a billion). A single stick (24' long) of 2x2x11 gauge weighs 73.2 lbs. Shipping costs are probably enormous (just guessing).Look around some more.
Reply:Prices are up. A 20' length of 2" square tubing with 1/8" walls is $40 at my local supplier.Jack OlsenMy garage website
Reply:Where in Ma. are you?....Try Mid-City steel....they are usually pretty good.Miller Syncrowave 180Miller 211 w/ spool-gunLincoln Ac/Dc buzzboxCutmaster 38 plasmaVictor,Smith's,and Craftsman (Harris) O/A torches.DeWalt Multi cutterFiber Metal helmets(old school)Enough Snap-On to be a dealer
Reply:Originally Posted by ChrisA7164Where in Ma. are you?....Try Mid-City steel....they are usually pretty good.
Reply:Originally Posted by Jack OlsenPrices are up. A 20' length of 2" square tubing with 1/8" walls is $40 at my local supplier.
Reply:37 and change for 2 x 2 x 1/8 @ 20'Where are you getting the gauge material? I have a tough time finding stuff like that out this way.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Originally Posted by ed macive never seen 20ft tubing all 24' i just orderedangle - 20 ft2x2x1/8 $21.30 eachsquare - 24ft1x1x14 ga. $22.32 each1x2x14 g $32.04 eachex. metal 3/4 - 9standed and flat 4x8 sheats $54.93 eachwith a $1000.00 order only $10.00 shipingto my door the last time i got 2x2 it was 3/16 and i thinkis was just under $50.00 ill check
Reply:Heres what I pay 2x 2 x 1/4 square tube 96" @ $ 36.25 each
Reply:BlauSchuh,HOLY SMOKES BATMAN! I can get a 24' stick of 3x3x11 gauge for $57.19.1 cut (usually in1/2) to make transport easier is FREE.I couldn't afford to weld at the price you quoted. WOW!
Reply:Originally Posted by joedirt1966BlauSchuh,HOLY SMOKES BATMAN! I can get a 24' stick of 3x3x11 gauge for $57.19.1 cut (usually in1/2) to make transport easier is FREE.I couldn't afford to weld at the price you quoted. WOW!
Reply:Go to your local welding supply store and ask them....if they don't know where to get the steel your looking for in your area no one will. Wouldn't hurt the cause if you bought a little something either. That's what I did and I couldn't be happier with the place they suggested. Price is price. Sure I could maybe drive 20/30 miles out of my way for maybe a little cheaper price but unless you're going to be doing high volume stuff I doubt you'll save anything worth the time and drive.Just my 2 cents...good luck to ya.
Reply:I'm paying $.30 a pound for surplus and about $.70 a pound for new at SSS in Houston.ChrisLincoln Pro Mig 180TMiller Spectrum 375
Reply:I shop at Discount Steel in Ft Worth, they also have a webpage with prices but the prices in person are a little cheaper.I just bought some "drop" for .45 per lb.They have a lot of drop and I can usually find what I'm looking for.You can check them out at discountsteel.com
Reply:Not getting a volume discount, I pay .50/lb for tubing and .70/lb for plate in the PDX area (surplus).Lincoln SA 200Esab Caddy 160Thermal Arc 201TSMiller Dialarc HFI don't like making plans for the day because then the word "premeditated" gets thrown around the courtroom....
Reply:dubl_t , do you ever try cherry city metals in salem? They have pretty good prices as well.Common sense in an uncommon degree is what the world calls wisdom.
Reply:Everybody should be converting their prices to $/lb. Then you have a common value to compare. Understanding, of course, that lighter dimensions will usually cost more.
Reply:.48 a pound for new in Los Angeles, then. But other local suppliers charge considerably more. And if any charge less, well, I'd like to know about them. Jack OlsenMy garage website
Reply:Originally Posted by Brainfarthdubl_t , do you ever try cherry city metals in salem? They have pretty good prices as well.
Reply:If I was you and was looking to get a good price try finding a local manufacturing shop in your area and see if you can order through them. Places like that get a great discount because they order in bulk and sometimes they have material laying around that is not needed and you can get it for alittle more then scrap price. I get all my steel through the company I work for and it is usally around 4 times the price of buying it myself from local steel companys.Miller XMT 304Lincoln Buzz BoxVictor Cutting Torch OutfitHobart Generator/Welder
Reply:Originally Posted by runserjohnIf I was you and was looking to get a good price try finding a local manufacturing shop in your area and see if you can order through them. Places like that get a great discount because they order in bulk and sometimes they have material laying around that is not needed and you can get it for alittle more then scrap price. I get all my steel through the company I work for and it is usally around 4 times the price of buying it myself from local steel companys.
Reply:I was just at the metal supply place on thursday and if i remember right the prices were:2x2x20 .065 $20 something2x2x20 .120 $322x2x20 .188 $65And for sheet 3/16" was .50/lb. I got a 5x8 sheet sheered into 5 pieces for ~$150. Normal price to sheer is $10 a cut or $60/hr but i think they either forgot to charge me or were just being nice since they couldnt cut it the first time i came.Last edited by ggarner; 07-17-2010 at 03:10 AM. |
