side ramp on trailer
发表于 2021-8-31 23:50:56 | 显示全部楼层 |阅读模式
put a side ramp on a trailer today Attached Images
Reply:Looks Good. Now talk them into a JACK!
Reply:I like the Modification!  Looks great...Also, looks like a 'no frills' kinda trailer, but would be VERY effective for hauling some toys and accessories.  Are there plans for 'that particular' trailer?  It looks quite 'simplistic' from here... but..Cheers,/FC..Miller Diversion 165120 amp Buzz BoxVictor Oxy/Ace Oxy/LPGSmith "Little" Oxy/LPGHypertherm Powermax 30Lot's of Misc. tools n' crap....
Reply:I like it. Nice job!!!!
Reply:Looks like you did a fine job from here, but if I could offer a little advice for future reference. The angle frame is o.k. for lite duty kinda stuff but if they are gonna be riding 4 wheelers or commercial lawn equipment up it, over time it will bend and bow. You may want to build the next one with 1"x2"x14 ga. box tubing, much stronger and will last longer. By the way, what are those frame looking pieces in the background going to be used for?I am what I am, Deal with it!If necessity is the Mother of Invention, I must be the Father of Desperation!
Reply:I like your gate and I like your latches. I built a ramp gate for myself this year and I still haven't found a latch that I think is perfect. (I've reworked it 3 times). I might have to try it your way.Thanks
Reply:thanks guys, i dont like tubing it rust from the iside outits good to see your back dabar 39 im in palm bay stop by
Reply:Nice work. As you know, this style trailer derives its strength from the bottom as well as top angle (or pipe) and now that there's a void in the top rail between the end of the tongue channel and front spring hanger, have you considered adding a piece of 'tongue size' channel (or angle) under the side angle to eliminate the 'weak link' created by the removal of the section of top rail for the side gate?  Just a thought.And yes, what are those racks on the other side of the handcart?MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:Here is one I did 5 years or so ago. Its a 24 inch rail all the way around so I made the side ramp fold to match the height of the rail. Attached ImagesUA Local 598
Reply:Originally Posted by dabar39Looks like you did a fine job from here, but if I could offer a little advice for future reference. The angle frame is o.k. for lite duty kinda stuff but if they are gonna be riding 4 wheelers or commercial lawn equipment up it, over time it will bend and bow. You may want to build the next one with 1"x2"x14 ga. box tubing, much stronger and will last longer. By the way, what are those frame looking pieces in the background going to be used for?
Reply:Originally Posted by MondoLooks great!  I like the idea of side loading for ATVs and mowers.  You don't have to unload everything in the back to get one off the front.My thoughts on using box tubing for trailer frames:Moisture gets trapped inside and corrodes it from the inside out and there is no stopping it.  Capping the ends is the worst thing you can do.  Moisture likes to get into small places ands stay there doing it's dirty work.  But leaving the ends open doesn't guarantee they will dry out inside between wet spells.Channel shapes and I-beam and H-Beam shapes have a chance to dry off in still air and don't trap condensation.  And you can easily clean and repaint all the surfaces periodically which can't be done with box shapes. - Mondo
Reply:Originally Posted by duaneb55Nice work. As you know, this style trailer derives its strength from the bottom as well as top angle (or pipe) and now that there's a void in the top rail between the end of the tongue channel and front spring hanger, have you considered adding a piece of 'tongue size' channel (or angle) under the side angle to eliminate the 'weak link' created by the removal of the section of top rail for the side gate?  Just a thought.And yes, what are those racks on the other side of the handcart?
GMT+8, 2025-12-24 16:53 , Processed in 0.081086 second(s), 18 queries .
