Everlast 62i power factor correction
发表于 2021-8-31 16:58:51 | 显示全部楼层 |阅读模式
Any one know if the 62i plasma has power factor correction.  I am looking at buying one to drive one off a 12kva generator with a 32 amp receptacle when away from the workshop but experience has shown me some machines which invariably are the cheap generic chinese stuff are a mixed bag when it comes to generator use.  The ones with power factor correction seem to be the ones to get for generator use.I know the specs for the 62i say 10kw generator required, but is that for flat out?
Reply:Cheap or not, many machines have a PFC lower than 99%. We recommend using only clean power output generators.  10kw is what you need if we recommend it.  That is based off the inrush not continuous.  .Regardless, we recommend the generator output be considered "clean" which is 5% or less THD. Many companies have this. One of the best, but lowest priced models is the Northern  Tool PowerHorse line.  The problems aren't so much with the "cheap chinese plasma cutters", as it is with the cheaply made generators which are designed for maximum profitability designed only to run resistive loads and not electronic ones.Esab Migmaster 250Lincoln SA 200Lincoln Ranger 8Smith Oxy Fuel setupEverlast PowerPlasma 80Everlast Power iMIG 160Everlast Power iMIG 205 Everlast Power iMIG 140EEverlast PowerARC 300Everlast PowerARC 140STEverlast PowerTIG 255EXT
Reply:Yea I have worked out my generator should run it OK. It will get loaded up pretty well though.  It is a low THD generator,  under 4%.  I think I will order one as there are very limited options in this country for single phase 60 amp plasma cutters.
GMT+8, 2025-12-19 00:36 , Processed in 0.096087 second(s), 18 queries .
