miller 250 feed question
发表于 2021-8-31 23:50:49 | 显示全部楼层 |阅读模式
I have a miller 250 mig welder and the wire feed drive roller sits too low in relation to the gun end.Are there any adjustments ? I need to either raise the drive or lower the feed/gun mount Bracket.I do not currently have this machine on site so I am trying to get as many ideas as possible for when I will spend some time with it next week.Thanks to everyone. I also posted this on the Miller site.Tim Beeker.
Reply:You might need to be a bit more specific as to exactly which model welder or feeder you have.  Miller made a few different migs in the 250 class over the years.MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:It is a Millermatic 250. I got a couple replies on Miller board, I am going to check out the motor bushing tomorrow.Tim Beeker.
GMT+8, 2025-12-24 18:37 , Processed in 0.091910 second(s), 18 queries .
