6010 5p+ and 5P differences
发表于 2021-8-31 23:50:48 | 显示全部楼层 |阅读模式
I am wondering what differences there are between 5P+ and plain old 5P rod. The literature from Lincoln doesn't do a good job  explaining it.
Reply:Originally Posted by TazI am wondering what differences there are between 5P+ and plain old 5P rod. The literature from Lincoln doesn't do a good job  explaining it.
Reply:i think the 5P+ has a small amout on iron powder in it.only thing worse than an ugly woman is an ugly weld
Reply:5P is red, 5P+ is greyDisclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I personally prefer 6011. 6010 would be my next choice, then 6010+. Most of my welding career it was 6010 root, hot pass and fill, then 7018 cap. I even remember when it was required every pass uphill. NO downhill! And yes I'm aware 6011 is an A/C rod while 6010 is D/C. 6011 is actually A/C-D/C. I no longer weld new pipe as I'm retired and old oilfield pipe responds very well to 6011.
Reply:The 5P+ can handle more of a gap, if you can't get it going down with the + then go up.  A bloody good rod.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
GMT+8, 2025-12-24 18:15 , Processed in 0.130450 second(s), 18 queries .
