do i need Ac welding output ?
发表于 2021-8-31 23:50:43 | 显示全部楼层 |阅读模式
hey guys (and gals) , im an apprentice in the pipe and steamfitters union , i have been in for a little over 4 years , we do carbon steel pipe welding , and stainless steel pipe.  there is also a specialty place we work at that does hasteloy , al6xn , 2205 , 304 ........yada yada ....my question to you is this.  I want to purchase a Generator Welder unit for the back of my truck , i kinda wanna stay lincoln , and i see they have the 250gxt , and the 305g of the 2 i really would like the 305 because of the pipe welding , and the chopper technology , but it doesn't have AC.  will i miss it ? i know i don't weld aluminum , so my only concern is in case i needed it for magnetized material out in the field.  the welder will be mainly used for home use , the generator , to practice on pipe for work , (stick , tig ) but only on stainless and carbon steel.  I also plan to do some work for farmers , and the amish up here as well on the side.so given what i have told you , will the 305g without AC be ok for me ? or do i need to stick with an AC/DC unit ?thanks alot - Art ps..sorry for the ramble"I'd Rather die on my feet , than live on my knee's"64' Lincoln Sa 200 Redface Code 5496 - Sold 72' Lincoln Idealarc 250 (Roundtop) MillerMatic Vintage
GMT+8, 2025-12-24 18:39 , Processed in 0.094072 second(s), 18 queries .
