riveted jon boat
发表于 2021-8-31 23:50:43 | 显示全部楼层 |阅读模式
i have a 10 ft waco  riveted jon that needs some repair. was gonna use 5356 but got to thinking i heard somewhere riveted were made from different type sheet then all welded. i know most welded are either 5052 or 5086 anyone have an idea riveted are from wondering if i should go 4043 or 5356 ???350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:What type of repair are you tackling?  I am not sure what series of aluminum those riveted boats are general made of, but welding them have always been sketchy.  Of the succesful repairs I have done on riveted boats I have the best luck with 4043.  Although I only attempt welding when there are tears or punctures.  I try to use rivets as much as possible, with appropriate seam sealer.Jay DavisAWS-CWIC-60 Specialty Welding ContractorLoving husband, and father of two boys (
Reply:its small holes in the keel crimps my friend would pull it out of his truck and just drag it to the water over gravel dirt etc so he rubbed holes i know it is weldable because it s welded at the bow and transom350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
Reply:well the cracks were longer then i thought. it took a bit but i got it fixed with a mix of pulse mig and tig  was a bit dirty and some was so thin it vaporized chased a couple holes and got her fixed no leaks. took it out on a lil river put it through the paces and it was fine 350P 30A spool gun cut master 51  syncro 250 other stuff " take a dog off the street and make him prosper and he will not bite you sad the same cannot be said for man" i didnt use punctuation just to piss you off
GMT+8, 2025-12-24 18:26 , Processed in 0.075615 second(s), 18 queries .
