A little 7018 on a hot day
发表于 2021-8-31 23:50:39 | 显示全部楼层 |阅读模式
It's been a bit warm and humid in western Illinois and I had to do some face buildup on some ductile parts.Usually I just mig these and toss them in the furnace, but Saturday I thought "put the Portacool at your back and just stick 'em, take your time". It's just build up and going to go away but after finishing I thought "man that rod runs really smooth". Then I thought of Farmersamm...Pic below; Oh the proud welded ring is so the cutting tool can get a load on a small surface before hitting the uneven welded surface.Matt Attached Images
Reply:Sometimes it's relaxing to run stick after you've run MIG for a while. That's one reason I used it on the ring roller instead of wire.  Looks goodMillermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:I guess i'm weird i learned and only stick welded for years then switched to mig. Maybe its cause i don't stick enough anymore but it just doesn't work for me. I would much rather pull the trigger and go as long as needed without stopping.Millermatic DVIMillermatic 251Older buzz box Cheap 120 welder
GMT+8, 2025-12-24 20:10 , Processed in 0.072794 second(s), 18 queries .
