Some fab work on my bike
发表于 2021-8-31 23:50:38 | 显示全部楼层 |阅读模式
I'm trying to hide the tube's that I had cut by boxing them in.chicken poop here 22ga I gave upWent and got some 3/16 plate...this I can work withtry that with a torch(I say that cause I don't have one)Drilling for the seat postEven I can weld thatThe far right weld was vert up,only took one to find out vert down is flatter
Reply:What's that frame carrying motor wise? It looks like you need to do some work on that.....Last edited by Rojodiablo; 02-28-2010 at 07:19 PM.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:This is it a few weeks agoAs it is now
Reply:We all have to learn some where or how just hope no one get's hurt in the process.To me that is scary!!!!!!!!!!!!!!!!!!!Just my 2 centsMiller 330 A/BP Bernard SS coolerMiller cst 250Miller Big Blue 251DCentury 210 Mig (first welder I bought)Hypertherm PowerMax 800Victor torch setRu Fong 31 MilAtlas lathe
Reply:I ride a Honda.Can someone tell me why every harley has a bell on it?Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:By the way. Nice springer conversion hardtail.Enjoy the ride brother. You have a better back than I do.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Originally Posted by Joker11I ride a Honda.Can someone tell me why every harley has a bell on it?
Reply:Originally Posted by toolmanWe all have to learn some where or how just hope no one get's hurt in the process.To me that is scary!!!!!!!!!!!!!!!!!!!Just my 2 cents
Reply:OOOOHHHHHHH!!!!See, that's why I ride a Honda.....they are Gremlin Free. hahahahahaJust kidding. I want a Road King for daily driver and I want a GoldWing for my road trips. Sorry. No hijack intended.Lincoln Power Mig 210MP MIGLincoln Power Mig 350MP - MIG and Push-PullLincoln TIG 300-300Lincoln Hobby-Weld 110v  Thanks JLAMESCK TIG TORCH, gas diffuser, pyrex cupThermal Dynamics Cutmaster 101My brain
Reply:Goldwings are nice,I escorted 35 from a cruise ship one time....best riders that I have ever rode with.
Reply:So this is to hide the cut tubes?
Reply:Yes... .  first pic shows I tried 22 ga...that was way too thin.I thought is was 1/8" because 2 were stuck together when I bought it.3/16 plate is way better to weld.By the time the motor is bolted back to iy and battery tray is in you really will not even see it.
Reply:Are the welds on the hard tail the same as on the box?I am tired of Ketchup, I want the Gravy...
Reply:Steel slug inside
Reply:So, As I see it, you are using your original Harley frame and have added a after market hardtail and are trying to hide those unsightly tube ends? I think what everyone is concerned with is welding on a motor vehicle of any type, car, truck, motorcycle requires a certain level of expertice in fabrication and welding as you life may be at stake. That said, it seems OK to do cosmetic welds as it appears this is, but on structural, such as the hardtail graft, make sure it done right. Other words, know your limitations. Its looking pretty cool so far, good luck.
Reply:Originally Posted by trapperjohnSo, As I see it, you are using your original Harley frame and have added a after market hardtail and are trying to hide those unsightly tube ends? I think what everyone is concerned with is welding on a motor vehicle of any type, car, truck, motorcycle requires a certain level of expertice in fabrication and welding as you life may be at stake. That said, it seems OK to do cosmetic welds as it appears this is, but on structural, such as the hardtail graft, make sure it done right. Other words, know your limitations. Its looking pretty cool so far, good luck.
Reply:Vince, the later pics you posted make it a lot easier to see what you're doing with the box. Easy enough to understand now that I see it in more dimensions.To help with weld quality, and to reduce the pidgeon poop, grind off the black scale, and bevel the areas to be welded. You will get better penetration, and the welds will wet in better on the edges. Also, from the amount of volcanic action seen, you might want to work with your wire speed to get a more consistent feed rate, and a smoother weld. While I understand the frame is not affected by that welding, that plate is holding the transmission there, and anything cracking or shaking loose will cause a real hazard for you.And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:Thank you  always open for advice,one of the reason I hang around this site is to learn from the pros
Reply:Hey man... Nice job. Real nice job on the hard tail.                                                          Pipehack
Reply:man.........the coolest guys alway chop the sportys,,,,,,,,,,,it ' s gonna be a bad a$$     rigid "chopper " man.        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:here's some Harley parts i painted for a chopper like yours a little while ago......bet it's your same peanut style chopper tank & fenders. Attached ImagesLast edited by woi2ld; 03-01-2010 at 05:31 PM.        thermal arc 252i  -  millermatic 350P -   miller XMT, cp300ts, 30a 22a feeders, buttload of other millers, handfull of lincolns, couple of esabs  -   Hypertherm 1250 G3
Reply:I ride bikes and built a few . But have never seen it done like yours, hope it works out and you enjoy it.Miller 330 A/BP Bernard SS coolerMiller cst 250Miller Big Blue 251DCentury 210 Mig (first welder I bought)Hypertherm PowerMax 800Victor torch setRu Fong 31 MilAtlas lathe
Reply:Good looking project, Vince. I'm looking forward to see it finished. Are you gonna have it ready for spring?Millermatic 175Black and Decker hacksaw
Reply:vince - take the time to rework those welds - a sporty is a real Vibey engine - if your welds are close to borderline - which with all due respect- they look like they are in the photos - (again with respect and politeness ) they'll get cracked up pretty good in little time.granted your front and bottom  mount are getting most of the engine vibes - your trans mount takes alot of torque load - it's not likely to come off in one shot - there'salot of bracing in there, but it,ll fracture and could cause misaligment issue with your drive chain  which 'could' be catastrophic if you dont catch it before it happens- the concept looks sound - material choice etc - you just need to get a better weld going. g'luck ! mGotcha Marc......believe it or not under that bead on the left is a pretty decent bead.I was just building it up some.woi2ld   wow some nice looking tins,when I get ready to paint I'll have a few questions for you.coreshotThank you  I only work on it on weekends so ready by spring? will be close.Next up is re mount the motor install chain,so I can mount the oil tank and be sure that it clears.Mount battery traysort wiresThen tear it all back down...check welds and smooth everything upPaint
Reply:Vince, yours looks better than this one, I believe it was fabbed with Hickory rod, spray transfer . Attached Images"Si Vis Pacem Para Bellum"Lincoln Idealarc 250 AC/DCMillermatic 251   Syncrowave 300   30A spoolgunLincoln MP210Hypertherm 45(2) LN 25(2) Lincoln Weldanpower 225 CV(4) SA200   1 short hood    SA250    SAM 400
Reply:Hey, where did you get that picture of my bike????????????
Reply:Just about doneNotice the block holding it up?Found out that a 99 engine will not fit in a 88 frame unless you cut off the kick stand.I have a weld on type on the way
GMT+8, 2025-12-24 18:37 , Processed in 0.391207 second(s), 18 queries .
