Small Caps Welded..
发表于 2021-8-31 23:50:36 | 显示全部楼层 |阅读模式
This is a fitting that came off a pressure line to feed a rear air conditioning unit on a RV...The customer don't want the rear to work anymore.. Anyway there were 2 of these to do so the customer could block off the line..Don't ask me why..I just work there.We all know how easy it is to turn something this small into a molten puddle of aluminum in short order..The welder was set to 200 amps..3/32 red tungsten..Straight argon this time..1/16" 5356 filler..Positioner in use...I have not welded anything this small in a while..I get all the fun jobs.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Almost perfect... just a wee suggestion for improvement; I detect an apparent lack of fusion between the dime and the cap. Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Originally Posted by Rick VAlmost perfect... just a wee suggestion for improvement; I detect an apparent lack of fusion between the dime and the cap.
Reply:Great job done the hard way.   I think that I would of cheated and crimped the tube coming from the fitting and brazed that shut. Nowhere near as neat as your fix.Millermatic 252XMT 304'sDynasty 280DXHypertherm PowerMax 1250Miller Trailblazer 302 EFIOptima PulserXR feeder and XR Edge gun and more athttp://members.dslextreme.com/users/waynecook/index.htm
Reply:Good looking weld Zap! Send the guy to western Il we had a 101 heat index today and everyone around is complaining that work is slow...I'm sure somebody will open them back up for the poor guy.Matt
Reply:when i first looked at the pics I said wow he's gonna use a dime to fill that hole. LOLAdam MMorales Ranch
Reply:Beautiful!!Miller TrailBlazer 251Miller HF-250-1Miller MaxStar 150 STLHyperTherm PowerMax 380 plasmaLincoln PowerMig 180Millermatic 252Miller Diversion 180
Reply:Ol' Zap almost  always puts a dime in the pic for size reference if something in the background doesn't give a reference. It's a good thing because if you haven't seen something personally sometimes it's hard to visualize the size of it in a pic.  By the way, Zap, that is a mighty fine small weld!!!                                                      MikeOl' Stonebreaker  "Experience is the name everyone gives to their mistakes"Hobart G-213 portableMiller 175 migMiller thunderbolt ac/dc stick Victor O/A setupMakita chop saw
GMT+8, 2025-12-24 18:35 , Processed in 0.099318 second(s), 18 queries .
