Bobcat Resurrection
发表于 2021-8-31 23:50:36 | 显示全部楼层 |阅读模式
I aquired a late 70s early 80s Bobcat 610 from a farmer that I did some work for. It was a swap for work and parts. He told me that the machine needed a new motor and he just wanted to scrap it. I took it back to my house and me and my father (owner of our company) go it going in about 30 min. The engine was 180 degrees out of time. Once we got it running we decided that we could go ahead and bring it back to life as a working machine. We have so far invested about 500 dollars into the machine, including the amount of work and parts we traded it for. I am now tearing into it an "puffing it up" a little to make it operate better and also look a little better.Here is where it stands now, basically day one of the rebuild. There is some welding to be done on various areas and I will post those pictures to keep this thread welding related. Attached ImagesCain's Mechanical LLC Southwick, MAwww.cainsmechanical.comRig:-2006 Chevy 2500 utility body-Lincoln Ranger 10-Miller Spectrum -Tons of hand and power toolsAWS D1.2 Structural Steel Certification
Reply:I had 1 at one time. 4cyl wis. motor.  motor can be hard to find parts for. good little workhorse.have fun with it. BE CAREFUL with no cage!!!!daye
Reply:The cage is off only while we are working on it to make it easier to access. You can see it in the last picture next to the machine.Cain's Mechanical LLC Southwick, MAwww.cainsmechanical.comRig:-2006 Chevy 2500 utility body-Lincoln Ranger 10-Miller Spectrum -Tons of hand and power toolsAWS D1.2 Structural Steel Certification
GMT+8, 2025-12-24 20:11 , Processed in 0.095527 second(s), 18 queries .
