good criteria fro a mig weld
发表于 2021-8-31 23:50:34 | 显示全部楼层 |阅读模式
I was wondering what the criteria were for a good mig weld. I know that arc is 2x diameter and no more than 1/8 high, but i'm not sure for mig. Any help would be nice. thanks
Reply:It depends on the connection design. The engineer will give every parameter in print. Or is this just hobby-work or practice? Just make them uniform. Consistant, consistant, consistant. You want a nice even heat signature.City of L.A. Structural; Manual & Semi-Automatic;"Surely there is a mine for silver, and a place where gold is refined. Iron is taken from the earth, and copper is smelted from ore."Job 28:1,2Lincoln, Miller, Victor & ISV BibleDanny
Reply:criteria would be the same. when going from stick to mig the code does not give you the freedom to have more undercut, porosity, etc.only thing worse than an ugly woman is an ugly weld
Reply:Mark,If you're talking stickout, there really are too many variables to give a definitive answer.Depends on a multitude of factors such as:  wire size, solid vs flux core, voltage/amps, short arc or spray, etc. etc etc.You may wish to download Miller's Guide to GMAW which is available on their website.  It goes into great detail about how stickout affects the weld bead.  One of the better references on the subject that I've seen.Syncro 250 DX Dynasty 200 DXMM 251 w/30A SG XMT 304 w/714 Feeder & Optima PulserHH187Dialarc 250 AC/DCHypertherm PM 1250Smith, Harris, Victor O/ASmith and Thermco Gas MixersAccess to a full fab shop with CNC Plasma, Water Jet, etc.
Reply:el lloydeo i would think then that the very worst thing might be a bad ugly woman welder?
Reply:weldbead, i think youre right! lolonly thing worse than an ugly woman is an ugly weld
GMT+8, 2025-12-24 18:37 , Processed in 0.092739 second(s), 18 queries .
