My Truck Rack
发表于 2021-8-31 23:50:22 | 显示全部楼层 |阅读模式
I had posted this on another site i frequent so its a copy and paste lolI started to plan it out a while back then said  I'll do it on the flyearly in the week i told the boss to order 2 extra sticks when he ordered up the steel for the railing on the stairs we builtwe have used 1 1/4" ever since i started working for him. and that's the limit to what i can fit in the stake holes lol so of course this time he changed up to 1 1/2" lolso i ended up spending WAY more time on the stake hole legs then i wanted but its all sorted out and should look like its all 1 1/2" usedhaven't decided if i want to run a single hoop up around the cab or twins. i plan to mount lights down the road when i can afford them. but i will build in wire management when i decide so they are hidden as much as possibleHavent decided exactly what lights i want to use. i know i want to add some LED cargo's i have, but beyond that i haven't a clue lolwhat would you add? (truck is used for work and play and DD)might do something like thesehttp://grote.com/product.php?product_number=G6002have used these before there BRIGHT lol (red 48 diode unit)Pic's:some of the raw partsFirst rail tacked upRails endanother shot of the endSide shot of the truck with railsTop cross bar in the making Showing the step for the 3rd light on the truckTop bar is onanother shot of the top barI still need to finish this but its been way hot here and i just don't feel like doing it till it cools down, it needs a crosser at the front and finishing welds and grinding and then it can be cleaned and painted. Thoughts?
Reply:i like the top bar.looking at it , .i keep thinkin id have tried to do it with piecuts to keep   it one piece and easier to fit up..
Reply:I can't get all the full pics $%$@!#@$$%^%"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Weldbead - ya the top bar was parts left over from building trusses for a boat port, i could of made it one piece and bent it, just decided to use up the scraps lol farmersammwhat ones cant u see and i will see what i can do to make it better
GMT+8, 2025-12-24 20:09 , Processed in 0.092231 second(s), 18 queries .
