Miller Diversion 165?
发表于 2021-8-31 23:50:14 | 显示全部楼层 |阅读模式
Hey guysI want to pick up a Ac/Dc TIG machine to learn how to do aluminum.  I am ok on steel and stainless but could improve with that as well.  How is the new Miller Diversion 165?  The price is very attractive, but I am not sure if its good or not.  Says 230 volt input, that will work off a convention 3 pron AC outlet right?  Don't want to have to rewire my garage if I can avoid it.Would it be worth it to look at a Miller Diversion 165 or a Miller Syncrwoave 200?  Pros?  Cons?  Thanks all!
Reply:I have tried the Diversion and have a friend that has one. I think they are a decent machine. They run off a normal 220 welder outlet which I am sure you have or can put in without any trouble. The down sides for me were that it is only a 165amps machine max and only 20% duty cycle at 150amps. This means 1/8 aluminum is the max and you are greatly restricted. Also you can't arc weld ( stick ) with it which really sucks. As to the bigger machines. The Miller Syncrowave or the Lincoln Precision tig 225 are pretty good machines. I was going to buy the snycrowave 200 but the Precision tig 225 was 500.00 less. Both are the same machine just one os red and the other is blue. I bought the lincoln and so far love it.Good luck with your decision.Miller DVI2Lincoln Precision Tig 225Thermodynamics Cutmaster 38Everything else needed.
GMT+8, 2025-12-24 18:37 , Processed in 0.095377 second(s), 18 queries .
