New guy, just a simple question.
发表于 2021-8-31 23:50:12 | 显示全部楼层 |阅读模式
Hey guys (and gals),I'm new to welding, recently got my self a Millermatic 140 so I could do a couple things on my car. Thing is, there's quite a bit of pitted surfaces on my strut towers. I have drilled out the spots and have removed the strut cap. The thickness of the caps are around 14 gauge and some areas are pitted pretty bad, around 20 gauge. I've grinded and flap wheeled the surface, so there's no rust left on it, just some concave surfaces on it. My question is, is it possible to run some beads up and down on the pitted surfaces and then grind it flush with the rest of the metal? Or would I have to cut out the pitted metal and weld in a patch?Thanks!
Reply:how is your welding expierence? put some pictures of some practice welds. if you feel confident i would put in apatch if your gonna do it you probly only want to once if your gonna trade it soon just flush itQuality is our policy.
Reply:I'm using 0.023" wire with C25.
Reply:if i were you i reccomend filling and grindingQuality is our policy.
Reply:Alright thanks!Came out like this...still gotta do a bit more.
GMT+8, 2025-12-24 20:02 , Processed in 0.092288 second(s), 18 queries .
