I set up at 150 amp 75 balance 100 hertz and this is what happened. Uploaded with ImageShack.us
Reply:Uploaded with ImageShack.us
Reply:Loss of shield gas? Appears to be a bunch of whitish-yellow tungsten oxide deposited on the inside of the cup.
Reply:I do notice when I close the tank it will drop on the gauge. I will check the hoses and gauge tomorrow. Also if i turn the amp down to around 120 it works fine.
Reply:What type of tungsten is that?TA Arcmaster 300CM3XMT 304S22P12 suitcase feederX-Treme 12VSOptima pulserTA161SMaxstar 150STLHypertherm PM45OP setupStihl 020AVP, 039, 066 Magnum
Reply:What machine are you working with ? Originally Posted by angel85lxI do notice when I close the tank it will drop on the gauge. I will check the hoses and gauge tomorrow. Also if i turn the amp down to around 120 it works fine.
Reply:check your lines, it seem like you are getting oxygen in your shielding hose. The purple ball is normal, and the coloring means its clean , when it get a grey flaky look its crap.Miller bobcat 225g - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:info...... machine, amps, shielding gas, tungsten type, etc.....Miller bobcat 225g - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Red tungsted, everlast pro 205 , pure argon , 150 amps .
Reply:3/32 tungsted
Reply:If set it at 120 It's fine
Reply:Normally ceriated (gray band) will take the heat much better on AC than thoriated tungsten (red band). I'd switch to ceriated for aluminum. I learned on balled pure (green band) but once I made the switch to ceriated I never looked back.
Reply:So a air leak can make it explode like that. In.the last pic u can see like the aluminum exploded.
Reply:Originally Posted by angel85lxSo a air leak can make it explode like that. In.the last pic u can see like the aluminum exploded.
Reply:Originally Posted by Donoharmit is the red tungsten that exploded not the aluminium.use grey(ceriated) or gold(lanthanated)(both good for every material you will ever have in front of you) 3/32 will work the whole amp range of your machine.till you get the new tungsten set the ac freq at 60hz, your red tungsten will like that, also don't pulse.I will explode if I see another bad gas suggestion btw |
