I am having problems with the wire feed in my Lincoln SP175 plus
发表于 2021-8-31 23:50:11 | 显示全部楼层 |阅读模式
I am having problems with the wire feed on my welder, when I lift up the cover to watch the spool spin I see the wheels spinning on the welder but it is not grabbing, I am not sure if it is friction, but I tighten the spring that holds the contraption down, does not do anything, the wire comes out in spurts? I am using .035 wire, I have 75/25 gas and using it off of my dryer plug in. In which the last 30 days I have been welding 1/4 steel, I have had a couple certified welders getting me going on this, and everything was great until tonight. Please let me know what you might think what the problem was. I have the setting at J and wire speed at 8    Thanks
Reply:Dirty or kinked gun liner or bad tip would be my first guesses.MM200 w/Spoolmatic 1Syncrowave 180SDBobcat 225G Plus - LP/NGMUTT Suitcase WirefeederWC-1S/Spoolmatic 1HF-251D-1PakMaster 100XL '68 Red Face Code #6633 projectStar Jet 21-110Save Second Base!
Reply:My guess would be the same as duaneb55. But you may want to look at the feed tension arm also. Attached Imageswww.georgesplasmacuttershop.comPlasma Cutter and Welder Sales and Repairs--Ebay storeTec.Mo. Dealer Consumables for the PT and IPT torch's
GMT+8, 2025-12-24 18:37 , Processed in 0.088459 second(s), 18 queries .
