brand new suitcase 12vs dosnt work
发表于 2021-8-31 23:50:10 | 显示全部楼层 |阅读模式
I've been playing around with this feeder for a hr now set on the tb302 is cv hot matched to feeder. Power cable is in cv receptical nothing is working. I need some help!
Reply:Dosnt feed or display
Reply:Need some more details on your hook-up. Electrode cable hooked up to back of suitcase, ground cable hooked to ground, voltage sensing cable hooked to ground, power switch on & display should light up.
Reply:Are you sure that your TB is putting out power? Do a spark test or check with a meter.Not to be offensive...the power switch on the 12VS works upside down. Make sure you have it on.Check the circuit breakers inside the case.Pics of all your settings and connections might help.If all else fails, hook the 12VS up to another machine and see if it powers up. It will power up on either CC or CV regardless of where the switch inside is set, it just won't weld right if they don't match.
Reply:Forgot to mention if the power unit is set on cv rocker switch inside box should be set on cv also.
Reply:I have a LN25, although it's not Miller, sometimes the plug works loose at the place where the liner attaches to the feeder, the plug, not the brass thingy that goes into the feeder."Any day above ground is a good day"http://www.farmersamm.com/
Reply:Also, this is Lincoln (sorry), but ya gotta set the selector switch on the main panel of the portable welder to the wire feed position, mine is in the range selector knob.None of this advice is worth a crap I guess cause I run all Lincoln stuff, again.....sorry"Any day above ground is a good day"http://www.farmersamm.com/
Reply:Like the others have said the ground is a biggie if it is not hooked up the suitecase wont power it seems simple but it can fool ya.Ron
Reply:Do you have the 14 pin cable hooked up and mode set to CV remote controlMy is set up right now for FCAW so running DCEN but it would still work but would not weld well Forgot to switch my leads at first the other day when i was using it Backed my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:VS needs to be set to panel, not remote.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:Killdozer, The OP has a VS not an RC feeder, so he doesn't have a 14 pin cord like you do..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
Reply:OOP'S trying to help I gotta git my butt back to workBacked my CATMA over your CARMA oops clusmy me  What would SATAN do ?? Miller Trailblazer 302 AirPakMiller Digital Elite  Optrel Welding HatArcair K4000Suitcase 12RC / 12 VSHypertherm PM-45Rage 3 sawRusty old Truck
Reply:I was just trying to feed the wire threw the gun at the time, didn't figure I needed to hook up both grounds for the feeder to even turn on. Thanks for the reply's. Problem solved.
Reply:Dang I bet the pro chicoms were all reaqdy to pile on a dead miller. Dont know if those simple fixes are a blessing or a curse makes ya get real mad when itsso simple but so hard to seeMillermatic 252millermatic 175miller 300 Thunderboltlincoln ranger 250smith torcheslots of bfh'sIf it dont fit get a bigger hammer
GMT+8, 2025-12-24 18:39 , Processed in 0.071105 second(s), 18 queries .
