my welding cart
发表于 2021-8-31 23:50:06 | 显示全部楼层 |阅读模式
so this is my first welder that weighs under 300 pounds. so i figured i needed to add a little weight. i turned the heavy duty 110v extension cord (10 ga wires) into a light duty 220v cord. i think it is about 40 feet long. put a couple of 110 plugs on the top for grinders and such, will be putting a spool on the left side for the leads, and a 20 lb co2 bottle mounted under the handle. Attached ImagesLast edited by turk; 08-14-2010 at 04:04 AM.Dynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Turk:I have to warn you about your current operation. Having been in electronics for over 30 years I note that using your welder this way is causing the electrons to have to flow uphill putting a terrible strain on them........Sign on East Texas payphone: Calls to God 40 cents......it's a local call...
Reply:lolDynasty 200DXPassport plus w/ spoolmate 100victor 315c oxy/(act and prop)Miller digital elitemilwaukee power tools
Reply:Originally Posted by StampederTurk:I have to warn you about your current operation. Having been in electronics for over 30 years I note that using your welder this way is causing the electrons to have to flow uphill putting a terrible strain on them........
Reply:Originally Posted by turkso this is my first welder that weighs under 300 pounds. so i figured i needed to add a little weight. i turned the heavy duty 110v extension cord (10 ga wires) into a light duty 220v cord. i think it is about 40 feet long. put a couple of 110 plugs on the top for grinders and such, will be putting a spool on the left side for the leads, and a 20 lb co2 bottle mounted under the handle.
Reply:One other thing.  I know it's cool in Alaska, but you should still leave room for air flow from the cooling fan."The man of great wealth owes a peculiar obligation to the State, because he derives special advantages from the mere existence of government."  Teddy RooseveltAmerican by birth, Union by choice!  Boilermakers # 60America is a Union.
Reply:Originally Posted by bert the welderBut if he puts an electro-magnet on his ground clamp wouldn't that help over come the McBill effect of the gravitational friction caused by the charged nono particles emulated from the conductivity reaction between the concrete floor and the particular,South Taiwan, rubber used in the tires????  Double check with Tom Cruise, but I think you may need a roll of tin foil and some non-metallic Christmas ornaments to rectumfy this dangerous situation. Back to you , Stamp...........
Reply:The neutral is not even used in a 220 volt circuit.  How does it balance one?Larry "I feel for the man who cannot spell a word more than one way."  by Mark TwainLincoln AC225-SLincoln Weldpac 100 Miller Matic 180 (auto set)Miller Spectrum 375 ExtremeMiller Spoolmate 100Victor Super Range II
GMT+8, 2025-12-24 21:34 , Processed in 0.096647 second(s), 18 queries .
