D.O.T Welding Test
发表于 2021-8-31 23:50:00 | 显示全部楼层 |阅读模式
I am currently up at Suny Delhi in NY working on my A.W.S tests. on March 10th we are taking the NY D.O.T ( 1 inch thick plate). the thing is... i dont live in NY! I live in CT and most likely will be working in the state of CT. What is the CT D.O.T like? any different?
Reply:Not a clue, but if you can pass the NY test you should be home free!David Real world weldin.  When I grow up I want to be a tig weldor.
Reply:what are you going to run jordan vertski up brah? haha
Reply:hahaha good call testa! i love forums!
Reply:should of done my test on ACgot that arc blow at the last inch and a half of my root pass= failthey are coming back the 17th of april though, another shot!
Reply:If you had really had arc blow on you NY DOT test then you did not fail. That said I doubt you had arc blow. I would have passed my Mensa test but I took the right handed test with a left handed pencil."Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." -- Seneca the Younger
Reply:I must remember that excuse I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:ha...well believe it or not, i got either arc blow or my rod angle was too steep, its not an excuse it was my own fault.what makes you guys think i didnt have arc blow? just curious.
Reply:where was your ground.
Reply:exactly hrdhatdivrit was off to the side somewhere, i should of had it much closer to my plate
Reply:If you get arc blow you deal with it, crank the rod over, twist it, whatever it takes.  If it's not right then you do the repair.  (It may have been flux heavier on one side than the other)  so you deal with that to.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:Originally Posted by wirehuntIf you get arc blow you deal with it, crank the rod over, twist it, whatever it takes.  If it's not right then you do the repair.  (It may have been flux heavier on one side than the other)  so you deal with that to.
Reply:Joscerb55,I would be very surprised if the coupons you were provided had enough of a magnetic field to produce arc blow. Even with poor placement of ground. If they in fact did I would challenge the test. Additionally, changing to AC is not likely an option. The WPS will need to be followed. The AWS D1.5 (NY DOT) test is one of the only that will not allow the use of a grinder and is a very good test of a welders ability."Religion is regarded by the common people as true, by the wise as false, and by the rulers as useful." -- Seneca the Younger
GMT+8, 2025-12-24 20:09 , Processed in 0.092181 second(s), 18 queries .
