Lincoln MIG 180T
发表于 2021-8-31 23:49:57 | 显示全部楼层 |阅读模式
Just bought this welder, and have been using it with .35 flux core wire.  Whatever came with the welder when I bought it.  Was looking at using CO2, as I was just at Lowes and they sell the small cylinders.  But I need some sort of adaptor to run the C02...a Lincoln® S19298.  Can't seem to find it anywhere on the web.  Can someone help me out?  Thanks.
Reply:http://www.airgas.com/browse/product...&WT.svl=191563but you will also need a Plastic washer for these adapters.Got a LWS?You can also e-mail a couple vendorshttp://www.weldingmart.com/http://www.brweldingsupplies.com/Last edited by Broccoli1; 03-25-2009 at 02:57 PM.Ed Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:You may wish to take a look at this web site and learn it, they could sell to many welders but if they are setup ok they say so Gas Saver System at http://www.netwelding.com/
GMT+8, 2025-12-24 20:33 , Processed in 0.070806 second(s), 18 queries .
