ln-25 or suitacse 12vs?
发表于 2021-8-31 23:49:56 | 显示全部楼层 |阅读模式
hiI want to buy a wirefeeders for my buisness. i have always work with a suitcase 12 vs  and its a really good product.But i want to know how is the ln-25? fiability, solidity etc..Thanks alot for your answer
Reply:The LN-25 is the toughest most reliable suit case feeder which I have used. I have not used any for the last several years.
Reply:I don't think you can go wrong with either. Get the one that matches your wleder."Where's Stick man????????" - 7A749"SHHHHHH!! I sent him over to snag that MIC-4 while tbone wasn't looking!" - duaneb55"I have bought a few of Tbone's things unlike Stick-Man who helps himself" - TozziWelding"Stick-man"
Reply:the search box is your friend.   this exact topic has been covered several times.  I had an LN25, though I prefer my current ESAB300AVS.  so that's one more to consider as well.  any of the 3 will work great for u thoughTiger Sales:  AHP Distributor    www.tigersalesco.comAHP200x; AHP 160ST; MM350P,  Spoolmatic 30A; Everlast PowerTig 185; Thermal Dynamics 60i plasma.  For Sale:  Cobra Mig 250 w/ Push-pull gun.  Lincoln Wirematic 250
Reply:I bought a beat up used LN-25 and love it. Make sure to get one with a contactor and gas valve.
Reply:6 in one half dozen in the other, I have 2 beat up old Hobart Hefty's that I love.Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:LN-25You wont step foot on a commerical construction job (at least in the bay area) and see anything but Lincoln equipment.  Millers seem like better shop/small Rig welding equipment,  I prefer Miller, for shop welders, but if i were in the market for a mobile setup id be looking for a vantage machine and ln-25.  They are tough as nails, i worked as a pile driver, and they got dragged through mud, rained on, kicked, stepped on, dropped, smashed, and anything else you could imagine, and they just keep on working. Just my 2 cents
Reply:The LN-25 was an old war horse, but the new Millers are in a Pelican case http://pelican.com/Disclaimer; "I am just an a$$hole welder, don't take it personally ."
Reply:I've used both, give me the Miller vs
Reply:the Hobart heftys i had were hit or miss on wire speeds when having an inspector bust your balls on WFS per teh WPS.the Lincolns and millers were always pretty spot on.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
GMT+8, 2025-12-24 20:03 , Processed in 0.088924 second(s), 18 queries .
