shop floor thoughts
发表于 2021-8-31 23:49:56 | 显示全部楼层 |阅读模式
I am getting a workshop, wife approved (she wants to be able to use the garage again), location (due to cost) requires elevated floor. I will have a concrete pad in front of it to weld on (I am a hobbyist, so not going to cost me money when it rains), but would like to put maybe tile or some sort of reasonably safe flooring for welding/grinding small projects and general upkeep. I am looking for ideas, but inexpensive basic tile is looking good. I wont work on any cars in it. shop size will be 26x20, 10 ft walls so I can have tall shelf storage.point of post. when concrete isn't an option, what kind of reasonable cost tile or other flooring is best?Hobart Handler 190 Century 90amp on FluxCraftsman 200amp buzzbox
Reply:I have a basement under part of my shop... the floor over that section is concrete over joist. I think the concrete is about 2 or 3 inches thick. The building was built in the 30's and has held up very well. I just need to remember not to get the forklift over that section or it will be in the basement. They have new concretes designed specially for floor topping. The can go down as thin as 1/4" and hold up well.
Reply:It's hard to beat plain concrete on a shop floor. Almost any ceramic tile will crack when you drop something heavy and the grout lines are just a lot more effort to sweep. Vinyl tile is a possibility, but will burn and stain with much use. You could patch and paint the concrete if necessary, but use the epoxy garage paint. It will not burn or wear as much as standard floor paint.Burt _____________________Miller Syncrowave 250Millermatic 211Miller 375 Plasma Cutter Hobart Handler 12010FtDrillBit.com
Reply:I use bare concrete for a shop floor and really like it.  I had the concrete guys put a good polish on it so it is very smooth - easy to roll stuff on and easy to sweep.  I hate the idea of having to maintain epoxy or paint - especially since I end up welding on the floor from time to time.Hobart LX235Victor 250 Oxy-Acetylene Rig (welding and cutting)Bobcat 773F-350, 1999, 4x4, 16' 10K# trailerOutdoor Wood Burner - 10 cords/year
Reply:Originally Posted by forhireI have a basement under part of my shop... the floor over that section is concrete over joist. I think the concrete is about 2 or 3 inches thick. The building was built in the 30's and has held up very well. I just need to remember not to get the forklift over that section or it will be in the basement. They have new concretes designed specially for floor topping. The can go down as thin as 1/4" and hold up well.
Reply:Originally Posted by RyfI am getting a workshop, wife approved (she wants to be able to use the garage again), location (due to cost) requires elevated floor. I will have a concrete pad in front of it to weld on (I am a hobbyist, so not going to cost me money when it rains), but would like to put maybe tile or some sort of reasonably safe flooring for welding/grinding small projects and general upkeep. I am looking for ideas, but inexpensive basic tile is looking good. I wont work on any cars in it. shop size will be 26x20, 10 ft walls so I can have tall shelf storage.point of post. when concrete isn't an option, what kind of reasonable cost tile or other flooring is best?
Reply:Charley, do you mean Cement board?Hobart Handler 190 Century 90amp on FluxCraftsman 200amp buzzbox
Reply:Originally Posted by RyfCharley, do you mean Cement board?
Reply:Concrete, paddled very smooth, don't paint, or you'll be painting it the rest of your life! BTW, I wouldn't do the tile either, ceramic or vinyl.Bruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:What about Terrazo, like you would see in jails and older schools.
Reply:I think there are a lot of misconceptions about tile -- based mostly on what people have installed in their bathrooms.  Porcelain tile is the strongest.  But even lowly ceramic tile is -- in many ways -- significantly stronger than the concrete it sits on.  As with concrete, tile is stronger in compression than tension; so any voids underneath it will make it vulnerable to cracking under weight.  In a bathroom installation, this isn't a big deal, so the contractor will just dab enough thinset to make things stick.  In a shop installation, you butter both the tile and the floor surface.  When I had to remove some of my tiles for my lift install, I set a video camera on the floor and took a 4-lb sledge to the old tiles.  You can see the camera jumping from the impacts to the floor.  But the tile doesn't crack.I've had tile in my garage for four years, now.  I bought the cheapest stuff Home Depot carried.  It was .59/sf.  It's held up great -- even rolling a 500-lb engine over it perched on a floor jack or sliding 800-lb cabinets over it.  I've jacked cars up on it and dropped a lot of tools and other stuff.  If it does crack, it's easy to replace a tile.  I don't agree with gwiley.  It is MUCH easier to sweep than bare concrete, since bare concrete never looses its abrasive surface or stops producing concrete dust (unless it's treated or polished).  The tile surface is smoother than concrete and non-porous.  You can clean dried spraypaint off off it with a razor blade or a 3M pad.  I've had bare concrete before -- I prefer the tile.However, it is susceptible to burns from welding or grinding.  (I've got a lot of tiny pinhole-type burn marks.)  And it does need to be installed on a non-flexing surface.  Jack OlsenMy garage website
Reply:How about VCT (vinyl composition tile) on the rear part of the shop and leave the front part of the shop bare and seal it?tackleexperts.comwww.necessityjigs.comhttps://www.facebook.com/groups/mach...dingequipment/
Reply:Concrete. Back when I was a carpenter, we did several raised floor garages with concrete over wood framing. You might be surprised how affordable it is. The floor sheathing can be much lighter and cheaper with 3 1/2" of concrete over the top. Also, concrete is pretty easy and could be done DIY to save more money.Ian TannerKawasaki KX450 and many other fine tools
Reply:Hey Jack,I remember when you did some of your garage, VERY nice, I'm eating my words already.Last edited by Bruce; 06-02-2012 at 04:27 PM.Reason: more cypheringBruce The Welding ChefLincoln Weld-Pack 3200 NORWELD StickStanford Hill Farm
Reply:I would either go epoxy,which is what I did or have the concrete sealed.I have seen that done.Its easy to clean up.My epoxy floor has held up great considering the abuse I put it through.Its 12 years old and no peeling lifting etc....Go on Garagejournal Board.com, some great ideas.
Reply:I like the demo Jack, jeez your garage could be my kitchen! I am jealous lol. I like the cement board as an idea, will have to trial it on my garage floor or something,  I am still thinking about the cement over board as well, I would love any of these ideas probably, alot of decisions lol.Hobart Handler 190 Century 90amp on FluxCraftsman 200amp buzzbox
Reply:Originally Posted by Ryf..... location (due to cost) requires elevated floor......point of post. when concrete isn't an option, what kind of reasonable cost tile or other flooring is best?
Reply:sorry about the slow response, I have 4 problems with a whole concrete foundation slab right now, 1, cant find a reliable concrete guy, so the risk of having to do it twice isn't pretty. 2. I live on a hill so it requires a more substantial foundation/slab than just poor and go. 3. the distance from the road combined with hill is apparently enough that it will be a costly venture in man hours to get it done. I can build a floor frame myself which means zero man hours money wise. 4. i  live on a hill, this hill is part of a much bigger foot hill, when it rains we get immense amount of water traveling down off the hill, the building will be at the edge of the property at the lowest point the cost of redirecting that water without dumping it in the neighbors yard is prohibitive, and it would have to be redirected to keep it from going inside. if you go metal floor with slab on top, is it held up by steel or wood or?? 5" of concrete is pretty dang heavy, just not sure how thats supportedHobart Handler 190 Century 90amp on FluxCraftsman 200amp buzzbox
Reply:Originally Posted by Ryfif you go metal floor with slab on top, is it held up by steel or wood or?? 5" of concrete is pretty dang heavy, just not sure how thats supported
Reply:Originally Posted by dubl_tsteel beams with a pan deck, that's how most parking garages are done.Sorry you can't find a reliable mason, wish I was there
GMT+8, 2025-12-24 18:37 , Processed in 0.097363 second(s), 18 queries .
