Pro Con Pump question
发表于 2021-8-31 23:49:53 | 显示全部楼层 |阅读模式
I just finished up my home made tig cooler.I can't get a pressure reading off the gauge.I have the IN/OUT lines connected in series just to run the test.I tried turning the adjustment screw in a bit but the gauge did not budge at all.I see the fluid going through the lines,(I bought the clear reinforced lines). The gauge is plumbed on the correct side of the pump not the return.If I pump air into the gauge it works.I went on a Pro Con Website but could not get any answers. Any suggestions?.
Reply:a question for you, where did you get the pump and what are you driving it with?  I did the same building mine in house and it works ok, I never did put a gauge on it.  I purchased mine from a company that had a familiarty with the requirments for a tig cooler pump.  So the extra info might help getting some answers.
Reply:It sounds like you have no "restriction" to create pressure, on a tig torch there is a small orriface that the water passes through creating restriction in turn creating pressure, try putting a valve in line and slowly closing it.Don't close it all the way, Procon pumps are not designed to run without flow.
Reply:Originally Posted by LIGoombaI just finished up my home made tig cooler.I can't get a pressure reading off the gauge.I have the IN/OUT lines connected in series just to run the test.I tried turning the adjustment screw in a bit but the gauge did not budge at all.I see the fluid going through the lines,(I bought the clear reinforced lines). The gauge is plumbed on the correct side of the pump not the return.If I pump air into the gauge it works.I went on a Pro Con Website but could not get any answers. Any suggestions?.
Reply:OK I get it !!!! I will be back in garage in am and report back.Thank you !!
Reply:After you put the valve in the line to create a restriction you will be able to close this valve gradually and see the gauge reading go up. When it stops going up you will have reached the pressure setting of the built-in pressure relief valve in the pump. The screw adjustment on the side of the pump adjusts this relief valve setting. It's an upper pressure limit safety device. For a TIG cooler you don't want the pressure to ever go higher than 50 psi, so adjust this screw until the gauge reading drops to 50 psi with your flow restriction valve fully closed. If your your Procon pump was part of a carbonator in it's previous life this pressure relief is likely set at 120 psi and you should reduce it to 50 psi  Don't run the pump very long with no flow, as the pump will gradually heat up and destroy itself. A couple of minutes with no flow will not cause damage. If the pump will develop 50 psi or more while doing this it should make a good TIG cooler pump.You can see my DIY cooler here   http://weldingweb.com/vbb/showthread.php?t=34034CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
Reply:Thanks everyone,It works!! I ended up spending about an hour yesterday acutally hooking it up to the welder.I was able to restrict the hose on the cooler to give me a ball park setting.I then hooked everything up and turned the cooler on.It was set a bit high but adjusted it to just below 50 psi.I let it run for about 20 minutes just to check for leaks. I wanted to weld but as per my wife I had spent too much time in the man cave for the day !! LOL !! That WP-20 torch seems alot more  smaller and comfortable than the WP-17 torch.Its going to have to wait till next weekend.
GMT+8, 2025-12-24 18:36 , Processed in 0.114718 second(s), 18 queries .
