looking for info on a welder
发表于 2021-8-31 23:49:47 | 显示全部楼层 |阅读模式
my friend picked up a welder but there is no info that came with the welder.  tring to figure out anything that would be helpful i have a bunch of pictures the fuel filter was some he put on to help clear out the fuel line.  it has a chrysler flat 6 with a carter carb. i dont think it was orginally ment to be a trailer but the person that orginally bought it made it into a towable unit. if any info is possible email me at [email protected] Attached Images
Reply:I wonder if it is a Hobarttry over herehttp://www.hobartwelders.com/weldtalk/index.phpEd Conleyhttp://www.screamingbroccoli.com/MM252MM211 (Sold)Passport Plus & Spool gunLincoln SP135 Plus- (Gone to a good home)Klutch 120v Plasma cutterSO 2020 benderBeer in the fridge
Reply:very good call Broccoli1. i believe it's an old hobart g-412 400 amp dc welder. i have a 1965 hobart catalog that shows a close match to yours but with some modifications and upgrades which leads to yours being early 1960's. and in the catalog it shows the g-412 using a chrysler ind. 32 - 6 cyl engine. that's a BIG welder, the dims show 90 3/4" - L, 24" - W, 45 3/4" - H, and 2400lbs.johnjohnwelding instructorwww.williamrmoore.orgMooreTech College of Technologywelder/fabricatorJGWilson, Inc.www.jgwilson.com
Reply:http://www.jalopyjournal.com/forum/a...7&d=1103433692http://atlanta.craigslist.org/tls/1091535192.htmlLooks a lot like some of the old hobarts I have seen...That amp adjuster wheel especially.Smithboy...if it ain't broke, you ain't tryin'.
GMT+8, 2025-12-24 18:38 , Processed in 0.070351 second(s), 18 queries .
