Please check my coupon
发表于 2021-8-31 23:49:44 | 显示全部楼层 |阅读模式
I ran a few beads today just out of boredom, and the trouble I had a few weeks ago after not sticking for almost a year.  These did a lot better.  I bought new sticks.  I guess my old ones were bad.  Sorry the picture is bad.  My camera doesn't do well with close ups, but if you'd want to drive to Jackson MS to see them live, they'd knock your socks off! Stats:  All DC, stock is 3/16#1:  1/16" 6013 weave @ 60 amps#2:  1/16" 7014 @ 70 amps#3:  1/16" 6013 push @ 55 amps#4:  1/16" 6013 @55 amps#5:  3/32" 6011 @ 70 ampsComments please! Attached Images
Reply:What position where these in?I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:just flat on my work bench.
Reply:A couple of them look good, but I wouldn't know what these rod's weld like as I only use stovy rods and 7018.I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
GMT+8, 2025-12-24 20:01 , Processed in 0.115307 second(s), 18 queries .
