Tig Attachment for Arc Welder
发表于 2021-8-31 23:49:44 | 显示全部楼层 |阅读模式
Picked up an old craftsman 180/230 arc welder off of CL not to long ago from a guy going out of business, voluntarily.  He also sold me a tig attachment for it.  I can't find a lick of information on it anywhere.Anyone ever seen these?
Reply:Is it AC or DC?I'd rather be hunting........USE ENOUGH HEAT.......Drifting around Aussie welding more pipe up, for something different.....wanting to get home.
Reply:its just one that gets clamped onto by the stinger?  They work fine as long as your gas is hooked up and you dont forget to turn it on .  You wont have a remote for the amps but you dont really need that.Have we all gone mad?
Reply:Bottle to flowmeter to hose to fitting for clamping stinger to hose leading to torch with an on/off control. I have this set up with my synchrowave, I also have a regular torch and pedal, but right now I am using the set up described above.
GMT+8, 2025-12-24 20:22 , Processed in 0.065145 second(s), 18 queries .
