My son is about to buy a lincoln diesel welderthat we do not have any idea how old it is. We think the amps are 230 amp. It has a four cyl diesel engine and the engine guages are at the lower left panel at the bottom. We sure would appreciate any help from ya'll!!
Reply:Post some pictures. Sounds like a 250 D but they have a 3 cylinder perkins. Mine was made in the middle 80s so that should give you some idea. The rest of the description sounds right.
Reply:we have a sa250 at work with a 4cyl continental diesel. pics are nice thoughBruce DeLaetHeavy Equipment Mechanic and Welder1948 SA-200 short hood1949 LincWelder 1801963 SA-200 red faceMiller S-32-P
Reply:sounds like an SA-250 to meVantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches.
Reply:Thanks Dualie:Can you tell me what I need to look for to id it better. I appreciate your info.Thanks
Reply:should say right on the name plate on the front what it is. the the Lincoln product code will give it away. Lincoln is really good about posting most if not all of their legacy info online so you can usually search by product code.Vantage 500's LN-25's, VI-400's, cobramatics, Miller migs, synch 350 LX, Powcon inverters, XMT's, 250 Ton Acurrpress 12' brake, 1/4" 10' Atlantic shear,Koikie plasma table W/ esab plasmas. marvel & hyd-mech saws, pirrana & metal muncher punches. |
