Burn pit for wood
发表于 2021-8-31 23:49:36 | 显示全部楼层 |阅读模式
I built a small burn pit for my freinds down the street. We like sitting by the fire at night.        Vernon Attached Images
Reply:very niceUA Local 598
Reply:Put a lid on it & toss on some steak.MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:I'll second that one. Give it the Ribeye test.
Reply:Nice design.I'm keeping this in mind for dual use.  Make a lid and use it for a smoker / cooker too.Great for arm chair grilling!
Reply:Originally Posted by WHughesvery nice
Reply:Originally Posted by MarkBall2Put a lid on it & toss on some steak.
Reply:Originally Posted by Tim MI'll second that one. Give it the Ribeye test.
Reply:Originally Posted by bargainfittingsNice design.I'm keeping this in mind for dual use.  Make a lid and use it for a smoker / cooker too.Great for arm chair grilling!
Reply:I like it Vernon! Simple, heavy and clean.Late fall fires with neighbors are the best, fire goes down = toss in some pine needles & sticks!You're a good neighbor.Matt
Reply:nice and stocky looking also, what did you use to make the drum? looks pretty thick
Reply:Originally Posted by Matt_MaguireI like it Vernon! Simple, heavy and clean.Late fall fires with neighbors are the best, fire goes down = toss in some pine needles & sticks!You're a good neighbor.Matt
Reply:Originally Posted by vandacootnice and stocky looking also, what did you use to make the drum? looks pretty thick
Reply:Nice work.  It's a classy design that's built enough to handle the job, but ain't rinky dinky like the "pretty stuff" is from the design stores.Lincoln AC225 and CartLincoln WeldPak HD and CartOne hand
Reply:Originally Posted by MonicaNice work.  It's a classy design that's built enough to handle the job, but ain't rinky dinky like the "pretty stuff" is from the design stores.
Reply:Yep my thought exactly !! Sure beats the garbage you see at WalMart. Lowe's & Home Depot I really think the dual idea of wood burner and grill would be great idea for that setup.Sickle & Eggbert rating    "Two Steaks UP"   Co-Own CNC shop:Miller :1251 plasma cutter, MaxStar 700 TIG/Stick, & XMT 456 Multiprocess Welder.&  2 Hypertherm HPR260's Plasma CutterSorry I had a bad stroke but now I am back.
Reply:Originally Posted by specterYep my thought exactly !! Sure beats the garbage you see at WalMart. Lowe's & Home Depot I really think the dual idea of wood burner and grill would be great idea for that setup.Sickle & Eggbert rating    "Two Steaks UP"
GMT+8, 2025-12-24 20:24 , Processed in 0.071410 second(s), 18 queries .
