Adapter Plate...
发表于 2021-8-31 23:49:35 | 显示全部楼层 |阅读模式
Here is a little adapter plate I was forced to weld today...There was no arc blow..Arc wander..Silent beam..Beam me up Scotty...None of that whatever at all..I just don't get it and glad I don't..Positioner in use...You can do funky shaped stuff on it!1/16" 5356 filler..3/32 Red SHARP!...Straight Argon..180-200 amps..Footpedal..Miller A/BP330..Water in torch...All that happycrap...Any guesses to what this will be doing?Sorry about the crappy pic #1..I'M a rookie with a camera..What is your guess?...zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:Small block chevy water pump flange?
Reply:Originally Posted by choyer27Small block chevy water pump flange?
Reply:Exhaust flange.Rick V 1 Airco Heliwelder 3A/DDR3 CTC 70/90 amp Stick/Tig Inverters in Parallel1 Lincoln MIG PAK 151 Oxy-Acet
Reply:Carbuerator test plate?
Reply:looks like you could put a egr valve on there
Reply:Adapter or aZapster???? A mount/ plate for a stand or brace for something???And then, after so much work...... you have it in your hand, and you look over to your side...... and the runner has run off. Leaving you holding the prize, wondering when the runner will return.
Reply:adapter for single barrel carbidealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Originally Posted by prop-doctoradapter for single barrel carb
Reply:kool beans  you get all to fun jobs idealarc 250/250 ac-dc tigidealarc 250/250 ac-dc tig #2 used for sticklincoln sp100hh125dual arbor grinder polisher30 yrs of hand tools52 pitch blocks 6p-26prake gauge -pitch gaugeG&D prop repair 918-207-6938Hulbert,okla 74441
Reply:Lovely welding as always.From the picture it appears the positioner can be pivoted and clamped manually in a variety of positions on it's horizontal axis. Is this correct?I'm thinking it might be handy to have a positioner that would do this, except rather than be clamped in one position it would be capable of moving on that axis while welding. This would be handy for welding tubing saddle joints.I've seen some very expensive positioners that can tip back and forth on the second axis while the object rotates, but those are beyond my budget.I have a bit of a plan for converting my homemade positioner to do the rocking motion, might give it a try.Have you ever encountered a need for that type of positioner?
Reply:Originally Posted by zapsterNope.....zap!
Reply:This one will go from flat like in the pic to 90 degrees and anywhere in between.With rollers holding the object on the other end it makes driveshafts and such easy and all done in one pass..Like this..I don't do much heavy stuff in that position..It don't like too much weight.....zap!I am not completely insane..Some parts are missing Professional Driver on a closed course....Do not attempt.Just because I'm a  dumbass don't mean that you can be too.So DON'T try any of this **** l do at home.
Reply:I'm thinking about making things easier when welding this type of joint. Ideally this would mean motion on that tip axis during weld. Attached Images
Reply:Originally Posted by weldbeadzap is a ford man
Reply:Ohhh, purdy welds.  Have you tried any other kinds of tungsten with your welder zap?  A lot of people seem to use thoriated (red) for almost everything when TIG welding.  I've been using zirconiated (brown) for AC on aluminum.  I've recently started sharpening the tungsten to a longer taper making it much more pointy and I feel that I get better arc starting.Miller 330 a/bp water cooledI believe in gun control, I hold my gun with two hands.  If you want to know why, click here.Buy American or bye America.
Reply:Originally Posted by pinjasOhhh, purdy welds.  Have you tried any other kinds of tungsten with your welder zap?  A lot of people seem to use thoriated (red) for almost everything when TIG welding.  I've been using zirconiated (brown) for AC on aluminum.  I've recently started sharpening the tungsten to a longer taper making it much more pointy and I feel that I get better arc starting.
Reply:I use 2% Ceriated (yellow or orange end) for aluminum welding. That is if I dont use 2% Thoriated.
Reply:hey zapster just curious, what do you usualy set your balance at?
Reply:Originally Posted by Shadillhey zapster just curious, what do you usualy set your balance at?
Reply:Originally Posted by zapsterNope..All I EVER use is Red End..If it works don't fix it.....zap!
Reply:Originally Posted by Matt_MaguireIf I use the 3/32" 2% RED with my SW275 the tungsten grows small bumps on the end, it gets worse if the machine is set to autobalance (maybe my arc length is getting too long?).I have better luck with 1/8-5/32" Green or 1 1/2% lanthanated at keeping a decent point.Nice looking adapter BTW!Matt
GMT+8, 2025-12-24 20:20 , Processed in 0.097326 second(s), 18 queries .
