welding wire spooler
发表于 2021-8-31 23:49:31 | 显示全部楼层 |阅读模式
ive got a chance to buy some mig wire from a manufacturing plant cheap. problem being it comes in barrels. any way to respool the wire back onto 46lb spools ? please help its cheap !MM 251MM 135Lincoln Pro cut 55Bobcat 250Miller Thunderbolt ac/dcolder ac forneyJackson nexgen 3n13-Smith OP setups97 Dodge dieselMakita chopsawJet swivel head bandsawlincoln tig 300/30030a spoolgunpuma port. gas air comp.
Reply:I use the metal lathe for spooling stuff all the time.Go slow and keep the fingers out of the snarls or loose them!tractor,loader.dozer,backhoe,and all the tools to keep em movin
Reply:Originally Posted by 1-800minerI use the metal lathe for spooling stuff all the time.Go slow and keep the fingers out of the snarls or loose them!
Reply:Sounds like a project for an old bicycle.....My name's not Jim....
Reply:I was actually looking to do the same thing. Someone gave me some 44 lb spools and I have nothing to run them in right now so I was going to turn them into 10lb spools. -DanOwnerDW Metalworks LLCMiller Trailblazer 302Miller 8RC FeederMiller Passport PlusMiller Dynasty 200 DX W/Coolmate 1Hobart Handler 135Hypertherm PowerMAX 30Smith O/A Torch SetPlus much much more
Reply:Originally Posted by engnerdanI was actually looking to do the same thing. Someone gave me some 44 lb spools and I have nothing to run them in right now so I was going to turn them into 10lb spools. -Dan
GMT+8, 2025-12-24 20:24 , Processed in 0.088166 second(s), 18 queries .
