First time welding, used a mig 220
发表于 2021-8-31 23:49:27 | 显示全部楼层 |阅读模式
My welder is a Lincoln Power Mig 180C. I have the Argon/CO2 mix. Ran it off a generator (which I think isn't supplying enough power)How can I make these better
Reply:OK, your photos are too poor to evaluate the welds, out of focus. I'm not a MIG welder, either, altho I have used it quite a bit. Rule # 1, always CLEAN the metal your welding, buff it with a wire wheel, grind it enough to remove rust and scale, something. The quality of the weld is susceptible to rust and scale especially with MIG and TIG. Stick, too, just not as badly.Only when the last tree has died and the last river has been poisoned and the last fish has been caught will we realize we cannot eat money.                                         -Cree Indian ProverbSA 200 LincolnVictor Torches
Reply:weld a little and keep changing your wire feed settings until you can get a solid arc.  set amperage based onmetal thickness, type, etc..  then get your wire feed speed right.  not sure what to tell ya about argon settings, never used it.  make sure you keep your metal CLEAN.  i saw one of your welds over the coating, and that was the only one i could realy tell was bad.practice, practice, and practice.  try to find someone to help ya a bit and it really isn't hard at allalso, you'll learn quick why welders never wear crocs.  that fur WILL catch flame.
Reply:yea I walked out later with them on to take pics
Reply:The brown soot may be an indication that you have a little bit of a gas coverage problem...but it is a bit hard to see.Smithboy...if it ain't broke, you ain't tryin'.
Reply:What size generator were you using?Lincoln 225 ACLincoln Mig Pak 15Lincoln Mig Pak 10Purox Oxy-Acet Outfit20 Ton PressHonda Generator
Reply:8000 watt generator
GMT+8, 2025-12-24 20:24 , Processed in 0.093184 second(s), 18 queries .
