Needing Welder Trianing Material
发表于 2021-8-31 23:49:26 | 显示全部楼层 |阅读模式
I am in need of welder training material, spcifically some type of a T-joint testing material, I'm having some trouble getting these tests to pass and want to see what criteria there is for this test.
Reply:You may want to ask the person/entity responsible for inspecting and administering the test what the specific criteria is for your specific test.Generally, you want to see all the qualities of a good fillet weld-Near flat bead face with few surface irregularitiesLeg lengths equal to plate thickness and equal to eachotherToes wet in with no overlap and straight, even toe linesNo voids inside the weld (porosity or slag inclusion)Fully penetrated rootGood fusion to both plates throughout the weldMM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
GMT+8, 2025-12-24 20:24 , Processed in 0.095407 second(s), 18 queries .
