Hobart Ironman 230 with infinite heat adjust
发表于 2021-8-31 23:49:22 | 显示全部楼层 |阅读模式
Is it possible to modify a welder with the notched heat setting like a hobart ironman 230, so that the heat setting is infinitely adjustable?
Reply:Infinite heat adjustment requires a bunch of electronics and would be very costly to do, even if you were an electronics engineer. I'm not aware of any pre-made modification kits for doing this. You would likely be much better off selling the welder that you have and buying a replacement that already has the infinite heat adjustment if you feel that you need it that badly. CharleyMiller MM252Miller Bobcat 225NTMiller DialArc HF / DIY Cooler2 Victor O/A TorchsetsMilwaukee 8" Metal SawMilwaukee Dry Cut "Chop" Saw 5 Ton Wallace Gantry Various Grinders, Benders, etc.
GMT+8, 2025-12-24 20:12 , Processed in 0.092681 second(s), 18 queries .
