No "V" blocks? Here's a setup
发表于 2021-8-31 23:49:19 | 显示全部楼层 |阅读模式
I've made setups like this with Bridgeports and other small turret millers through the years to work on the end of something long, and it is also done with parts too large for v-blocks.  Also 2-4-6 blocks can be asssembled similar for a vertical V-block if needed.Two Posts total, pics with text below;Matt Attached Images
Reply:And the finish (I wonder how ZTFab got all those pics in one post?)  MODERATOR thing?Matt Attached Images
Reply:Originally Posted by Matt_MaguireAnd the finish (I wonder how ZTFab got all those pics in one post?)  MODERATOR thing?Matt
Reply:Originally Posted by Matt_MaguireI've made setups like this with Bridgeports and other small turret millers through the years to work on the end of something long, and it is also done with parts too large for v-blocks.  Also 2-4-6 blocks can be asssembled similar for a vertical V-block if needed.Two Posts total, pics with text below;Matt
GMT+8, 2025-12-24 20:22 , Processed in 0.095300 second(s), 18 queries .
