Pig Spit
发表于 2021-8-31 23:49:16 | 显示全部楼层 |阅读模式
A few pics of the pig spit being fabbed.  No need to comment on my steel toed flip-flops ... I have since learned my lesson.Still some more work to go on i think it needs some checkerplate.MillerMatic180Miller 375 Extreme PlasmaOld but reliable O/A setupI'm a simple man. All I want is enough sleep for two normal men, enough whiskey for three, and enough women for four. - Joel Rosenberg
Reply:A few more ...MillerMatic180Miller 375 Extreme PlasmaOld but reliable O/A setupI'm a simple man. All I want is enough sleep for two normal men, enough whiskey for three, and enough women for four. - Joel Rosenberg
Reply:How does it cook?
Reply:Originally Posted by TigwldrHow does it cook?
Reply:i like how in the last picture, everyone including the dog is drooling over the meat.
Reply:That was our first "trial" cook ...  just to be sure we preburned it properly and it didn't taste like oil.  I'm picking up a 65 pound pig today and it goes on the coals at 4am tomorrow ... Hopefully it will cook nicely.  If not I'll never live it down ...MillerMatic180Miller 375 Extreme PlasmaOld but reliable O/A setupI'm a simple man. All I want is enough sleep for two normal men, enough whiskey for three, and enough women for four. - Joel Rosenberg
Reply:That looks big enough to cook what passes for a HOG around here.  Good looking work.
Reply:That thing looks great.  I'm about to start basically the exact same project, except a little bigger.  Got a 700 gal tank for the enclosure, and the spit my cousin built plugs into a 110v outlet and spins at 1rev/min and creates about 200ftlb of torque.  It's pretty ridiculous, i'm pretty sure you could roast a full buffalo on it.  Post up some pictures of the pig you do, and how you attach it to the rod, etc.  When you're roasting, is the fire under the pig, or are you just stealing coals from a nearby fire?Millermatic 135Syncrowave 250
Reply:Looks good. What did ya use for the exterior paint? Anything special?"The things that will destroy America are prosperity at any price, peace at any price, safety first instead of duty first, the love of soft living and the get rich quick theory of life." -Theodore Roosevelt
Reply:Thanks for the comments!  Hopefully nobody minds the pics I'm attaching of the pork on the spit.Motkrig - the motor I use is an old reduction drive motor with an old timing gear set to spin the spit.  It turns at 6rpm and the spit turns at about 2 RPM ... which I find is a bit fast.  I would like to get it down to about .5rpm  Sandy - I used high heat satin black bbq paint.  fired about a quart of it through a paint gun and it is holding up great.  Finished the deck with 2x8 cedar decking with a natural finish and dropped a set of old school bias plys on hotrod rims.MillerMatic180Miller 375 Extreme PlasmaOld but reliable O/A setupI'm a simple man. All I want is enough sleep for two normal men, enough whiskey for three, and enough women for four. - Joel Rosenberg
Reply:couple pics of the mounting and cooking.I had to wrap it in wire for the last 2 hours ... the spit turns a bit too fast and it started to flop around a bit.I'll reduce the drive speed to .5rpm when I build the adjustable motor/spit mount.MillerMatic180Miller 375 Extreme PlasmaOld but reliable O/A setupI'm a simple man. All I want is enough sleep for two normal men, enough whiskey for three, and enough women for four. - Joel Rosenberg
Reply:Looks great - I have that same problem with the flopping around.  My plan is to put a counterweight on the rod so that when the pig flops it's directly opposite from the weight, which will balance it out.  Also - I'm not sure about this one but I've heard that wrapping it in wire like that can make it taste weird from the galvanization burning off.  maybe that's only if it's in direct flames though - which it shouldn't be anyway.  Millermatic 135Syncrowave 250
Reply:a few new pics of the latest addons.Fabbed up a double latch and turn handle for the front door.  Skinned it in checkerplate, and put the lights on it.more to come ...  feedback appreciated.MillerMatic180Miller 375 Extreme PlasmaOld but reliable O/A setupI'm a simple man. All I want is enough sleep for two normal men, enough whiskey for three, and enough women for four. - Joel Rosenberg
Reply:This is awesome!
GMT+8, 2025-12-24 20:13 , Processed in 0.070861 second(s), 18 queries .
