Big honkin welding rod
发表于 2021-8-31 23:49:11 | 显示全部楼层 |阅读模式
check out this welding electrode a guy brought in yesterday. MASSIVE! Attached Imagesonly thing worse than an ugly woman is an ugly weld
Reply:I think I would be scared to burn that !!!
Reply:Better not get that one stuck, you'll never break it loose!MM350P/Python/Q300MM175/Q300DialarcHFHTP MIG200PowCon300SMHypertherm380ThermalArc185Purox oaF350CrewCab4x4LoadNGo utilitybedBobcat250XMT304/Optima/SpoolmaticSuitcase12RC/Q300Suitcase8RC/Q400Passport/Q300Smith op
Reply:Do you know what type it is? I don't see a type number imprinted on it, but it looks as if the blue band is part of the color code; is there a color on the holder end or on the flux too? Are you sure it's not just a giant SPARKLER?   [Where are the good colors when you really need them?]
Reply:That room looks like Sentinel Vocational center in Tiffin is it?When I was there my teacher had one that sizeIf it's too . get an office jobLincoln wp225g7 Lincoln 250 idealarcFrankenstein O/A set-up Weld-tech  tig set-upLincoln sp 175 plus profax  arc gouger
Reply:Originally Posted by DesertRider33Better not get that one stuck, you'll never break it loose!
Reply:"Any day above ground is a good day"http://www.farmersamm.com/
Reply:is that for hard facing
Reply:theres a company that makes mold build up rods that are pretty big.insert thoughtful quote from someone else2000 Thermal Arc 300GTSW 3.5 hours1946 Monarch 20 x 54 Lathe1998 Supermax 10x54 Mill2004 Haco Atlantic 1/2" Capacity Lasernot mine but i get to play with it
Reply:If stuck......................read my sig line.........................MarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:WOW!!!! That will not fit in my stinger. What do you think that is used for? Pipelines?
Reply:need big chipping hammerDaye
Reply:Now that is a serious rod   do they come with a tripod Lincoln 225 Tombstone,Miller Big 20,Hobart 180,150' Argon,A/D hobart hood 22 Ton Log splitter,79 F350 dump eats 4.75 TONS and still turns cutters,grinders,And a  Hypertherm POWERMAX 30
Reply:need 1000 amps to burn it..
Reply:Im pretty sure its for mold build up, heres a really good thread on it. Page three has pics of the actual welding with them.http://www.hobartwelders.com/weldtal...ight=big+welds
Reply:Originally Posted by weldbeadneed 1000 amps to burn it..
Reply:im not sure what it was. the guy told me it was a 7018 but there were no numbers on it. only the company name "weld mold" their website seems to be down. id like to order one just to have it. he said it requires about 1500 amps. i didnt measure the rod diameter but my magis eyeballs said it was 3/4" diameter. weighed a ton too. hahaonly thing worse than an ugly woman is an ugly weld
Reply:Originally Posted by Oldiron2Do you know what type it is? I don't see a type number imprinted on it, but it looks as if the blue band is part of the color code; is there a color on the holder end or on the flux too? Are you sure it's not just a giant SPARKLER?   [Where are the good colors when you really need them?]
Reply:why? the linked post about the guy using that is pretty cool but why not run a SAW, those rods are so big that if the 1500 amps is right then you have a pretty killer SAW and not much more equipment. no way you could hold that by hand plus anything you would weld with that would have to be pre-heated. sorry but i am always the guy that asks WHY
Reply:Ya might need one of these to power the welder............. Attached ImagesMarkI haven't always been a nurse........Craftsman 12"x36" LatheEnco G-30B MillHobart Handler 175Lincoln WeldandPower 225 AC/DC G-7 CV/CCAdd a Foot Pedal to a Harbor Freight Chicago Electric 165A DC TIG PapaLion's Gate Build
Reply:Read along here,,,,,  pay attention to Spook2's posts ......  http://www.hobartwelders.com/weldtal...ad.php?t=17241Then Spook2 started his own thread .....  http://www.hobartwelders.com/weldtal...ad.php?t=17891
GMT+8, 2025-12-24 22:11 , Processed in 0.097557 second(s), 18 queries .
