查看: 13|回复: 0
New Guy Needing Some Help
发表于 2021-8-31 23:49:09 | 显示全部楼层 |阅读模式
Im looking for a nice welding helmet and hear the fibre pipeliner brought up a lot. I want an autodarkening lens. Will this setup work. I start welding school in the fall. I dont have a lot of cash to spend but this falls into my budget. Thanks for the help in advance.The helmet link and lens link from amazon.Fibre Pipelinerhttp://www.amazon.com/Fibre-Pipeline...g_hu-rd_dp_imgArcOne S240-10 Shade 10 2-Inch by 4-1/4-Inch http://www.amazon.com/ArcOne-S240-10...I22CM3CYC87BTI
Reply:I've seen some on ebay that are auto-darkening and are adjustable from 9-13 for about the same price.  I myself have one from harbor freight with a solar lithium battery and it works great.
Reply:They work but to adjust upward in shade, youll have to get shade 1 lens to stack ontopbof that lens. But they do work.Miller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:You'll also find that those hoods are heavy and eventually bother your neck.Miller bobcat 225g  - spoolmatic 1Mm250 - 30a spoolMiller spectrum 375Thermal arc 95 Everlast Ex 250As the boiler turns, these are the days of our lives
Reply:Originally Posted by astaindsoul5446You'll also find that those hoods are heavy and eventually bother your neck.
Reply:I still use my old Huntsman 430P.  Who needs autodark anyway?Mike
GMT+8, 2025-12-24 20:24 , Processed in 0.095451 second(s), 18 queries .
