harley heads
发表于 2021-8-31 23:49:07 | 显示全部楼层 |阅读模式
i need a serious well experienced  aluminum tig welder to fill in the intake/exhaust ports on a harley shovelhead .. i have 2 front heads and i will remove the exhaust port and have the head ready to weld.. the one front head needs to have the port moved over 3/4" to the right so the hole can be bored back to 1 5/8ths.   the intake ports are 1 1/2" in diameter and will be moved 1/2" to the right again i need the ports to be filled in 1/2" so a new 1 1/2" intake hole can be bored.. i have plenty of pics to show what im doing... in the end it will have 2 front heads on the bike and two 38mm mikuni carbs on the right side and the exhaust on the left..  IF you think you can do this email me for pics @  [email protected]
Reply:Post your location and it will help to know where you are.
Reply:Ditch the mikunis and use s&s super Gs, and post the finished pic. Longevity 160sx Lincoln 140 miglincoln magnum spoolgunVictor torch and regulators
Reply:Originally Posted by hogDitch the mikunis and use s&s super Gs, and post the finished pic.
Reply:Originally Posted by tnjindI doubt very many shovels could handle dual G'sIt is an interesting project
Reply:Originally Posted by Swamp ratPost your location and it will help to know where you are.
Reply:i have a miller 165  - i also have argon/helium mix -- i also have the new micro torches but they wont weld that thick of aluminum -- i use the acr-zones  ARC TIME tungstens  try them and ya wont use anythign else..  i have no problems welding the aluminum any place else on the heads  i have a test head that i try stuff on.. i know i dont need such a high rate of gas flow inside the ports -- i really,really need someone with experience welding aluminum inside alum. ports  the ports are  1 1/2"  intake and ya need to go about 2" in the port.. since im moving the port over 1/2" there actually more room than the 1 1/2" hole ---- the exhaust port for the rear head thats a front head the exhaust port has to go over  3/4" and 2" deep -- this hole is larger and since i bored the new hole you actually have more room to weld...  when done the ports will have 2 bolt flanges welded on them..
Reply:Originally Posted by panhead100ciahhh have you ever built ANYTHING in the line of harley engines?  probably not.. your dividing the engine up -- each cylinder is now 671cc  even on a stock 80" the "G" is way to big  -- the mikunis have several jets to fine tune -- im sure you dont know that.. i also have EGT's to help set the jetting -- put your costume on and go ride your store bought bike.. lol
Reply:Originally Posted by panhead100ciEXACTLY  these clowns read magazines... they fail to understand your feeding 1 cylinder at a time -- its like the clown who says  " i have a .500 lift cam im gonna put a .700 in and make it really scream"  they have NO clue to the fact of needs more CI needs higher compression,exhaust,carb,gearing, you know i dont have to tell you..as is i run 24 motor  22 tranny and 47 rear -- they would run  24 motor 24 tranny and 51 rear and never understand why i leave them in the dust..  like the guy who told me --- i have big bore cylinders  "really?"  yeah i bored them out .090 o/s and next week im gonna put longer rods in and make it a stroker... lol lol lol
Reply:Is  Sunset , La  off I- 49 to far away?
Reply:got all my welding problems solved by Mr. Jim. that guy can weld like i have never seen -- closed the holes up on the heads to less than 1/2 -- they machined prefect, no pits,flaws,perfect -- i have never seen tig welding inside a port like that and so perfect --   head have no valve seats or guides as of now-- next is to send them to lloyd elliot to install the rowe seats,cast iron guides and the ferrea valves -- leinweber delivered the special cam the L3S -- the 38mm mikunis sit in alignment like i wanted as not to get in my way of leg room..
Reply:its just a mock up-- the carbs dont even have the brackets yet--
Reply:Who is "Mr Jim"?
Reply:Hell yeah man. Love the motor!
Reply:Jim Steck   @ AutoComponenti --   this WAS the exhaust  its now the rear head even though its a front head http://i1264.photobucket.com/albums/...dfinished2.jpg
Reply:this pipe is 1  3/4"  OD and 1 5/8" ID  mr jim welded the hole to less than 1 1/2"  fantastic -- this gives me extra meat when the head is ported-- no imperfections ,no cracks,
Reply:geezzee this thing dont post like my other site
Reply:the rear front head see the intake manifold??   its off of a buell -- perfect fit and angle
Reply:If you post links to pictures hosted on other sites, the forum won't re-size them to fit the page. If you upload them directly to WW using the Manage Attachments, the forum will then re-size them properly for the width of the forum screen.Just an FYI...PapaLincoln Idealarc 250 (circa 1962)Lincoln Weldpak 155 w/Mig KitLincoln Squarewave TIG 175thanks papa  i know there 2 dang big  sorry
GMT+8, 2025-12-24 20:22 , Processed in 0.097881 second(s), 18 queries .
