sheet metal term
发表于 2021-8-31 23:49:06 | 显示全部楼层 |阅读模式
first off im not a sheet metal guy. what is it called when they stamp the x in sheet to keep it rigid like the photo in the link? thanks http://beaconac.com/wp-content/galle...-duct-work.jpgMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:cross break  its to help stop the duct from bowing in and out when the air handler turns on and of
Reply:OK thanks I have a job where I need to get like 25 each. 13x4' bent like that to keep it from rattling in the airMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:Most duct that size doesn't need to be cross braced, unless you just like the look if it or unless the metal is very thin. How many cfm of air is going through it, & what gauge metal will it be ?Last edited by lstilts; 06-21-2012 at 04:35 PM.Mastering others is strength, mastering yourself is true power.
Reply:I'm sorry, is that 13 ft. X 4 ft, ?, If it is feet it does need to be braced. I thought it was inches.Mastering others is strength, mastering yourself is true power.
Reply:yes its 13' x 4'Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:you might want to read some smacna details...
Reply:13' long in one piece???in my area, we only stock 8',10' and 12' longs sheets. The long straight runs of duct that I usually see seem to be produced in half sheet sizes - I'm assuming for minimizing waste and to add structural integrity.Thermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:This isn't for duct work. My local supplier said he will cut it from a coil.Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:1.  first off im not a sheet metal guy. what is it called when they stamp the x in sheet to keep it rigid like the photo in the link? thankshttp://beaconac.com/wp-content/galle...-duct-work.jpg OK so far so good.  2.  OK thanks I have a job where I need to get like 25 each. 13x4' bent like that to keep it from rattling in the air.OK he needs ductwork, (that is what is shown in his link) and it is moving air (we assume) and he needs to make 25 of them.3.  yes its 13' x 4'Much bigger than anything shown in his link.4.  This isn't for duct work. My local supplier said he will cut it from a coil.Guess the reader will just have to wonder what he's talking about, if he knows.Last edited by fdcmiami; 06-24-2012 at 08:28 PM.Reason: deleted "clueless"  no need to be rude. lol
Reply:its for the side of a computer (data module) for transport. ill see what i have for images to explainMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:here is a photo of a older mod. now they are two of those that bolt together in the middle. ( long sides)  you have to ship it in two sections. so a cover needs to be made and bolted to the sides to enclose it. and it needs to be reusable. the sheet that covers the open side needs to be a little more rigid. it will have less support. Attached ImagesMiller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
Reply:sorry insufficient data.   however, back to the cross break yes it can be done;  there are dies that can be used to stamp the metal or it is placed in a break and done by hand.   you would probably need at least two cross breaks given the size limitations of common sheet metal brakes.there is preformed sheet metal that has stiffeners in place;  maybe look at that.  a standing seam arrangment could work also.   if it's been done before why not just do it again.is that the northrop plant in LA?   i swear i've been there.
Reply:Originally Posted by fdcmiamisorry insufficient data.   however, back to the cross break yes it can be done;  there are dies that can be used to stamp the metal or it is placed in a break and done by hand.   you would probably need at least two cross breaks given the size limitations of common sheet metal brakes.there is preformed sheet metal that has stiffeners in place;  maybe look at that.  a standing seam arrangment could work also.   if it's been done before why not just do it again.is that the northrop plant in LA?   i swear i've been there.
Reply:Sheet metal is simply metal formed into thin and flat pieces. It is one of the fundamental forms used in metalworking, and can be cut and bent into a variety of different shapes. Sheet metal is available in flat pieces or as a coiled strip. The coils are formed by running a continuous sheet of metal through a roll slitter.Sheet metal also has applications in car bodies, airplane wings, medical tables, roofs for buildings (Architectural) and many other things.i think this information will also help you.
Reply:Finding a 14' brake might be a challengeThermal Arc Fabricator 2101970 Lincoln RedfaceMiller 150 STLStill need a Syncrowave and a plasma and a milling machine and a lathe and a bigger shop and a....
Reply:Yes that is the hard part. I will probably have each section done with two cross breaks.Miller Pro 300 SS w/ cat Miller Bobcat 250Miller Diversion 165 Miller 211Miller Xtreme 375Miller 12vsMiller Dynasty 200 DX Miller Passport Plus w/ Spool GunMiller 30a spoolmaticLincoln AC225 Buzz Box VictorMathey Dearman - H&M
GMT+8, 2025-12-24 20:13 , Processed in 0.094960 second(s), 18 queries .
