查看: 2|回复: 0
Kawasaki Cutoff Saw — 14in., 15 Amp, 2800 RPM, Model# 841226
发表于 2021-8-31 23:49:06 | 显示全部楼层 |阅读模式
Kawasaki Cutoff Saw — 14in., 15 Amp, 2800 RPM, Model# 841226 i was thinking of buying this can someone tell me how to find a promotional code for nothern tool
Reply:going to tsc to get this for 99$ can someone tell me if i can put a diamond wheel on this it and if so can you recommend 1 to me 2800 rpm is a lot lower than the dewalt's
Reply:Not sure what you want to cut with a diamond blade. If you are thinking about using this saw to cut steel or alum with a carbide metal cutting blade, I believe the RPMs are still too high. Most dry cut carbide saws run at 1500 RPM or so.I can't say why the RPM's on this saw are so low for an abrasive saw. My guess would be simply a cost cutting measure to keep the price down..No government ever voluntarily reduces itself in size. Government programs, once launched, never disappear. Actually, a government bureau is the nearest thing to eternal life we'll ever see on this earth! Ronald Reagan
GMT+8, 2025-12-24 20:13 , Processed in 0.074273 second(s), 18 queries .
